Saved Old John Deere R92 Lawn Mower from Junk Yard
   / Saved Old John Deere R92 Lawn Mower from Junk Yard #1
DerekF
Bronze Member
North East, Arizona
Honda Recon, Husqvarna 440, Stihl MS180,
I found this old John Deere R92 in my local junk yard. I started to video it and decided I just wanted to get it done. I just did a basic carb cleaning, filled the tires with slime and put in new valve cores. Changed the oil. Cleaned the air filter (I'm going to be putting on a UNI filter here before too long) cleaned up the threads on the head of the motor for the spark plug and put in a new plug. Ran new fuel lines and fuel filter, greased and lubed everything, lubed the chains and dropped the mower deck to lube all the pulleys and install a new belt. I got it all back together after and mowed the lawn with it. Works great. I am going to use it this summer to keep the weeds down on the property I manage and then I plan to take it into my shop and this winter and take it all apart, clean it all up, paint it, and put it all back together for hopefully many years to come! This video is just a little introduction to it, Admittedly, its probably one of the worst videos I have ever made, the sound was messed up when I went to edit it and I was really shaky with the camer and I didn't show anything I did to it. Future videos will be better, I usually can make a half decent production . If you guys are interested in the future "restoration" please consider subscribing to my channel.
Awesome Junk Yard Finds and New Projects! - YouTube
Here is a video of more work I have had to do to this ole mower.
   / Saved Old John Deere R92 Lawn Mower from Junk Yard #3
It sounds like it may be a bit low on compression, but hey, if it mows, Git her done!
I probably need to take the head back off and use the RTV gasket goop on it. That would probably help. I have a compression tester. I need to test the compression for kicks and giggles. But it is in rough shape for sure. Still debating on how far I want to go with it!
2016 Ford F-550 Crew Cab Mason Dump Truck (A51691)
2016 Ford F-550...
2018 Ford F-150 Pickup Truck (A53117)
2018 Ford F-150...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
ALLISON TRANSMISSION (A53843)
ALLISON...
Frontier 60" Grapple (A50123)
Frontier 60"...
