I have an S-470D 3 cyl diesel, that starting loosing power. It ran for 30 - 40 minutes and then just died. I waited a few minutes and then hit the starter. Started up, ran for about 6 ft and then died again. It started for the 3rd time and then, just barely managed to creep back to the house and died again. I replaced the fuel filter and blew out/cleaned the air filter. It will crank over, but not start. I hit it with a couple shots of starting fluid and it almost acted as if it wanted to start. Had just a little black smoke coming from the muffler. I removed the three lines from the top of the fuel pump. Cranked the engine and had diesel sputtering from the two out side lines. Nothing was coming out of the center. There was very little volume with injecting force coming from the two outside lines. Is it possible to have the center plugged; or is my fuel pump defective? Any help will be appreciated.
