Hi guys I'm a long time listener, first time caller here. I've got a 2012 Kubota RTV400 (145 hrs)that is getting harder and harder to get started. The starter just won't crank it over. I have checked the battery and even a booster won't help it. I have found that if I remove the spark plug and crank it and then reinstall it, it will turn over just fine. I have also stuck a skinny screwdriver thru the flywheel cover and pryed on the fins to turn it over a little and then it will start. It seems that it has too much compression for the starter. I did some online research for similar problems and found a couple of different similar accounts. They both said a compression release is available for this unit. My local Kubota dealer service manager where I bought it can't find any info about it. Have any of you guys heard of this problem and have any solutions? I love the machine. I bought it because of the reliablity I have had with my tractor (L3400). However it's a real pain when it won't start when I need it.
