daTeacha
Veteran Member
I had a small Kubota B7100 with 15" rears. After loading those tires to 75%, the ride was much more harsh.
Pressure will be a major factor. With a loaded tire, 75% of the interior volume is now filled with incompressible fluid and only 25% with compressible air. Driving over an object will spike the air pressure faster than with the unloaded tire.
I just added about 130 lb of homemade wheel weights to my tractor. Haven't done enough with it yet to notice if there is a major increase in stability or not. I run 9 lb. of pressure in the rears (24" rims) with 900 lb. on the 3 point. The manual says only 18 lb. max. in the back tires, although the tires are stamped for 35. I did notice that running the rears at 17 psi on new limestone showed that only the center half of the rears was actually contacting the stones. With 9 lb, I get full contact.
