Roof Insulation vs. Condensation
   / Roof Insulation vs. Condensation #31
Another Pte for firing out the purlins to create an air gap, then adding soffit and ridge vents.
The inside face of the insulation will be 70 degrees and in winter the outside face will be 30 degrees. There is a 40 degree temperature drop through the insulation. If the dew point is at 50 degrees, then the dew point will occur in the center of the insulation. This is acceptable because the closed cell foam will not absorb any moisture.
Yes, spray foam the gaps after installation.
So you have a pole building with wood sheathing for the roof and walls? If so, that's ok because won't change the assembly.
Thank you for that.
2023 yamaha (A55758)
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A57192)
2001 WELLS CARGO...
2010 FREIGHTLINER CASCADIA TANDEM AXLE MID ROOF SLEEPER (A56138)
2010 FREIGHTLINER...
White Metal Roof Panels (A55758)
White Metal Roof...
2017 FOREST RIVER 20 T/A CARGO TRAILER (A53843)
2017 FOREST RIVER...
2015 Ford F-250 Auto Crane EHC32 3,200lb. 1.5 Ton Crane Service Truck (A55852)
2015 Ford F-250...
