I used the seat harness and the roll bar worked perfectly.
My Kubota B2630 was on its side for less than 15 minutes, supported by the roll bar, rear left tire, and the 60 inch bucket. No visible damage or problems. After a short while, it started on the third try and blue a good bit extra blue smoke, which I suspect was extra fuel spill into the muffler. After a few minutes all was normal. It started fine afterwards and seems normal, and all fluid level seem fine.
Even though it was on its side for such a short time, I have major regrets about attempting to start it those first two attempts. I worry that if there was a little oil in the cyclinder, I may have done some damage.
Before I begin using it again, I wondered what precautions to take, or what subtle things I should look for. What symptoms should I look/listen for now? Are there any tests I can do to check for a bent rod?
Are stupid mistakes covered under warranty or Kubota insurance? !!
I have just 35 hours on it, so I thought about taking it in early for the 50 hr service rather than doing it myself as planned; perhaps the pros will notice a problem I'd miss.
Curt
Curt
