Riding mower charging system
   / Riding mower charging system #1
Walt44
Livingston, Texas
Kubota L3010 GST /w/ LA 481 Loader, RTV x900
I have a Craftsman riding mower with a 15.5 HP Kohler engine. The amp needle sets a zero while the engine is running but does go negative while starting. How can I check the charging system to be sure the battery is receiving enough charge?
   / Riding mower charging system #2
Set your voltmeter to DC & start the tractor. At full throttle, check the reading across the positive & negative posts on the battery. If charging system is working correctly you should read about 14 to 14.5 volts.
2015 Yale MPB040-EN24T2748 4,000lbs Electric Walk-Behind Pallet Jack (A51691)
2015 Yale...
Mini Excavator (A52377)
Mini Excavator...
2015 Freightliner M2 106 Terex BT2047 10-Ton Crane Truck (A51691)
2015 Freightliner...
2025 Star EV Capella 2+2 Electric Cart (A51694)
2025 Star EV...
1981 LUFKIN 41 FLATBED (A53843)
1981 LUFKIN 41...
2015 Cadillac ATS Sedan (A51694)
2015 Cadillac ATS...
