Replacing Tie Rod?
   / Replacing Tie Rod? #1
MDSteve
Clements MD
Kubota 3710
I bent my tie rod on the 3710. I have a new one and would like some tips on getting the old one off. The one that I bent is the left one that is not adjustable. Thanks for the help.
Steve
   / Replacing Tie Rod? #2
Hi Steve,
I assume the problem you're having is breaking the taper press fit between the tie rod ball joint and the drag link. Since you're going to be replacing the tie rod, you don't have to worry about destroying the grease boot. In this case you can use a "pickle fork". You can buy these at most auto parts stores very cheaply. They fit between the ball joint head and the drag link. A sharp rap with a hammer and the tapered fingers of the fork will break the taper press.
There are also special pullers you can buy to do the job, or you can use a air hammer fitted with a blunt drift on the end of the ball joint stud. Using a regular hammer you can sometimes break the fit loose with a hard sharp rap, especially if a torch is used to heat up the drag link seat first. But you have to be careful using heat, most of these steering shafts have plastic inserts in their joints, which will be damaged from too much heat.
HTH
Dave Perry aka karmakanic
Thanks for the advice. Job was completed. I went after it with a hammer and it came loose within a few minutes.
Steve
RCcar RC-G2.0 Electric Golf Cart, NEW! (A52384)
RCcar RC-G2.0...
2008 KALMER 4X2 SPOTTER TRUCK (A51247)
2008 KALMER 4X2...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2011 Kia Sportage SUV (A51694)
2011 Kia Sportage...
2016 Case CX160D Hydraulic Excavator (A51691)
2016 Case CX160D...
2000 Ford F-350 12FT Stakebody Flatbed Truck (A51691)
2000 Ford F-350...
