Replacement engine for Onan P220G
   / Replacement engine for Onan P220G #1
Rusty
Hampton Township, Bay County, Michigan
Kubota B7500HSD-R
Does anyone have experience buying a complete engine from the Small Engine Warehouse? I am looking to buy a 10955-LX790-P220G 20 HP twin cylinder Onan engine, with two year warranty, for $1,275. The engine will replace the engine in my 1992 Toro/Wheelhorse 520-H garden tractor. Does a "complete" engine include all engine-mounted items, except the muffler? Thanks in advance, for any help that you can provide!!! /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
   / Replacement engine for Onan P220G #2
Rusty, I just got done replacing the old Kohler MV20 on my Ransome with an Onan P224V from Small Engine for considerably less $$ ($400 - $500) than if I had stayed with Kohler. I did not have one problem with it and would not hesitate to buy another from them if needed! Of course, changing engine makes I ran into some other issues, but the engine from SEW was not one of them. It came with everything except a muffler. It did have manifold pipes, 1 for each cylinder, but no mufflers - I cut these off, welded on a couple of female pipe connectors, and screwed in two $6 mufflers from NAPA. Dual exhaust sounds pretty cool too! Just make sure the output shaft is the proper size, both diameter and length, for your application.
2012 Honda Accord LX Sedan (A51694)
2012 Honda Accord...
2018 Sakai SW990-1 Tandem Vib Roller (A52384)
2018 Sakai SW990-1...
2016 Ford Focus SE Sedan (A51694)
2016 Ford Focus SE...
2019 MACK P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK P164T...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
