Removing Sidewalk to Nowhere
   / Removing Sidewalk to Nowhere #11
I'd build a shed or something else at the end of the sidewalk.
   / Removing Sidewalk to Nowhere #12
Put another pool back in!!! /forums/images/graemlins/laugh.gif
I joked with my wife that I was just going to put a refrigerator at the end of the sidewalk as a conversation piece. The electrical drop was there and everything. /forums/images/graemlins/laugh.gif
   / Removing Sidewalk to Nowhere #14
That would be a good conversation piece /forums/images/graemlins/smile.gif
You could stop on the tractor and pick up a cool one.
   / Removing Sidewalk to Nowhere #15
Come on Pete!
You enjoy golf (it's listed in your profile). You've got to build a putting green! /forums/images/graemlins/wink.gif/forums/images/graemlins/cool.gif You could have a bunker or two on each side to practice your sand shots. (That would require that you use your tractor to occassionally fill in the sand! /forums/images/graemlins/wink.gif)
   / Removing Sidewalk to Nowhere #16
As Bill mentioned, I'd rent an electric jackhammer. The previous owners of our house had plans to install a brick outdoor grill. They got as far as the concrete base for it, which I broke up with an electric jackhammer and a wheelbarrow (before tractor). When I told the rental place what I was going to use it for, the only question they asked me was "How far away from an outlet are you?" They wanted to make sure that if I used an extension cord, it was heavy enough so as not to result in too big a voltage drop.
   / Removing Sidewalk to Nowhere #17
well i like the electric jackhammer idea best, i think that would work better than a concrete saw. pallet forks work pretty good too, a few months back a friend up the street was going to break up a 10ft long section of sidewalk. he had just gotten out his electric jackhammer when i stopped by, he told me what he was doing so i said, hmm i could use that piece of sidewalk to put infront of the doorway of my goats barn so it isnt such a big step up and to keep the mud to a minimum. so i got my tractor and my 3pt pallet forks, tilted them down with my hyd toplink and slide them under the slab which was around 5 inches thick, lifted up and the whole piece came right out and i carried it home with ease, set it down where i wanted it and was very pleased, all with virtualy no hand labor
GolfGar, if I put in the putting green I will derfinately need the refrigerator. Perhaps even a medicine cabinet to hold my Motrin and Bandaids. /forums/images/graemlins/grin.gif
Electric jackhammer...I'll call right away.
Thanks
   / Removing Sidewalk to Nowhere #20
Pete , Make sure you get a Chisel(sp ) bit . The bits that are very pointed seem to get stuck easily. Also, as you break up the concrete , remove it . If You don't it'll tend to bind up nthe jack hammer . John
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2007 CAT 904B (A47384)
2020 Cat 299D3XE Skidloader (RIDE AND DRIVE) (A50774)
2020 Cat 299D3XE...
2013 Chevrolet Traverse LS SUV (A50324)
2013 Chevrolet...
2015 CATERPILLAR 326FL LONG REACH EXCAVATOR (A51242)
2015 CATERPILLAR...
2014 INTERNATIONAL LF687(INOPERABLE) (A50854)
2014 INTERNATIONAL...
