Remote, battery-powered watering
   / Remote, battery-powered watering #1
econometrics
Platinum Member
East Texas
Deere 5075E MFWD OOS w/PR, 540E; Gator 825i
Howdy all,
I have a 65 gallon spray tank that I have elevated about 3' off the ground to water a small garden on some land that has no power or running water right now. I only have 8 plants to water, and have an irrigation system set up.
The problem I am running into is that I cannot find a batter-powered valve/timer that works under low pressure.
How much PSI do you think I am getting from 65gal elevated 3 feet? The first timer I tried just did not flow: Amazon.com: Orbit 62001 Lawn and Garden Digital Watering Timer: Patio, Lawn & Garden
So now I am looking at this guy, which specs at 10-140psi for flow. It has a 5.2gpm flow at 30psi. DIG: 9001EZ-C Battery Powered Hose End Irrigation Timer
Any thoughts would be greatly appreciated!
Thanks!
   / Remote, battery-powered watering #2
Howdy all,
Thanks!
Water weighs .43# per ft of depth. At 3' the pressure is in the order of 1.25# plus any added pressure from the depth of the holding tank.
Yikes, thanks for helping me figure the pressure here. Bottom line, I need a lot more depth or more height it seems.
   / Remote, battery-powered watering #4
If spray tank holds air, you might be able to pressurize it enough to get your valve to work. Even if it blows, the only casualty will be the corn. I assume you have to come back fairly often to add water, so you can pump it back up.
Other option would be an electrical timer and put a small solar panel out there to run it. At some point you're paying about $20 each for carrots, you could buy certified organic grown by monks in Tibet for that price.
   / Remote, battery-powered watering #5
If he's only watering 8 plants they probably aren't carrots :)
OP - have you thought about a drip irrigation? A small drip irrigation with a low flow constant drip might do as well as a bigger flow on a timer.
You could have one or several small drip lines to each plant.
About 120 drops of water = 5 milliliter, so 90840 Drops in 1 Gallon. How many drops of water in one gallon
So do the math.
   / Remote, battery-powered watering #6
I have a similar situation on my block. I use a 23000ltr tank to water my garden. As the head is so low, I cannot use the normal valves.
I bought some stand alone battery timers designed to connect direct to the tap and run from a battery. They do not need pressure to operate as they have a motorised valve. I then have a trickle feed to the garden.
Weedpharma
Weedpharma
From the research I have been doing, this seems to be the route I am going to need to go. Thanks for the input from your experience!
newbury, I did think about the drip route, yes. That was going to be my "fall back" plan if I couldn't come up with anything else.
The garden is nothing too wild - a couple of pumpkins, squash, and tomatoes. We're mostly doing this as a "test plot" on some new land we purchased to see how things take. So, yeah, we're going to put a lot more $$$ into these plants than they are worth, but it's all about getting that experience - which is priceless - right? :laughing:
   / Remote, battery-powered watering #8
I just bought a 12 volt programmable timer and 12 volt, 1/2" gravity feed solenoid valve on Ebay in order to do the same thing you are. I plan on using a small battery with solar charger to operate the valve.
1 2" Gravity Feed Electric Solenoid Valve DDB CD 12VDC | eBay Valve
DC 12V LCD Digital Power Programmable Timer Switch Time Relay 16A US Shipping | eBay Timer
Jim
Jim, that is perfect! This is what I was looking to do, but didn't know where to start. Thank you!
How big is your tank, and how far are you watering?
   / Remote, battery-powered watering #10
It sounds like we have similar scenarios. I started a separate thread last week with my thoughts if you're interested. I'm totally in favor of drip irrigation and have used them in the past. I like the idea of the solenoid and timer suggested and will probably use the same. My biggest concern is how to fill my tank. How were/are you filling a tank that's elevated? Do you just fill it remotely and then lift it up? I'm planning on using a larger IBC tank (300 gallons), and I'm trying to decide how I want to fill it without power from a nearby pond that's 160 feet away. My default is to use a gas powered pump, but I'm seriously considering a wind pump.
2022 Spartan RZ-Pro Zero Turn Mower (A50860)
2022 Spartan...
1998 Pierce Enclosed Cab Fire Truck (A50860)
1998 Pierce...
2024 Icon LT-A617.4+2G Electric Golf Cart (A48082)
2024 Icon...
Coleman KT196 Go-Cart (A50860)
Coleman KT196...
2018 John Deere 60G Excavator (A50490)
2018 John Deere...
2015 CATERPILLAR 259D SKID STEER (A51242)
2015 CATERPILLAR...
