Recommeded hydraulic fluid for my 350 John deere dozer
   / Recommeded hydraulic fluid for my 350 John deere dozer #11
I would use jd hyl fluid only/tried tractor supply fluid/no wheres as good as jd fluid.Done a fluid change on jd combine affter couple hrs of operation hardly move,dumped out all fluid refilled with jd brand never a problem since,made a believer out of me,worth the few dollars more.
   / Recommeded hydraulic fluid for my 350 John deere dozer #12
Most industrial equipment has separate reservoirs for trans/hyd oil/ finials ect. If it is just for your hydraulics AW32 or AW46 depending on where you are at and how many leaks you have. Down south go with the 15 wt oil and up north the 10 wt. CJ
2019 MACK P164T DAYCAB (A48992)
2019 MACK P164T...
Little Giant Elevator (A49251)
Little Giant...
2024 Polaris General 1000 XP Premium (A47371)
2024 Polaris...
2009 JACK COUNTY KILL TRAILER (A48992)
2009 JACK COUNTY...
2017 Ford 550 XL, Cab and Chassis, Crew Cab (A47371)
2017 Ford 550 XL...
Skid Steer Auger Drive & Bit Set (A47371)
Skid Steer Auger...
