Rear Wheel Weight
   / Rear Wheel Weight #1
powershop
Bronze Member
Middletown,PA
BX2200
Can anyone tell me why Kubota says not to run rear wheel weights and filled tires at the same time? I have a BX2200 with FEL and wheel weights but need more ballast to do FEL work on side hills. Dan
   / Rear Wheel Weight #2
They don't want you to overload the axles. If you had wheel weights + fluid + something on the three point, you could potentially damage an axle.
Do you have something on the three point & still tipping? You may want to reconsider the slopes you are operating on.
I think you'd be OK with wheel weights & filled tires, provided you took off the weights when you used the three point hitch.
   / Rear Wheel Weight #3
You'd be better off putting on an attachment or making a ballast box for your additional weight. You'll get more "bang for your buck" so-to-speak by getting the ballast further back. By putting ballast 24" behind the rear axle centerline, you'll get the same counter-balance effect with approximately 30% less weight. ie. 100# at the wheels is equivalent to abount 70# 24" back.
   / Rear Wheel Weight #4
rlw,
you're correct for up & down hills, but not necessarily for side to side hills. Although, the more weight on the back end, the better.
Lets say you only have 200# to put on,
If you need a "wheelie bar" use weight off the three point
If you need "training wheels" use weight on the wheels.
   / Rear Wheel Weight
Thanks guys! I now have wheel weights at 70 lbs each. I can use my rear box blade, but was looking for lower center of gravity weight.(filled tires) But the owners manual warns against using both. Dan
   / Rear Wheel Weight #6
Do you have a MMM? Its a good way to add some weight nice and low & wide. I don't know how rough an area you are working, so ground clearance may be an issue.
Definitely put your box scraper on, that will help.
2013 Ram 1500 Pickup Truck (A51692)
2013 Ram 1500...
2014 FREIGHTLINER CASCADIA SLEEPER (A54313)
2014 FREIGHTLINER...
2025 K1220 UNUSED Single Garage Metal Shed (A53117)
2025 K1220 UNUSED...
2008 FORD RANGER SINGLE CAB TRUCK (A51406)
2008 FORD RANGER...
2018 CATERPILLAR 950GC LOADER (A51246)
2018 CATERPILLAR...
JOHN DEERE 437E KNUCKLE BOOM LOADER (A52705)
JOHN DEERE 437E...
