Rear tire stance adjustment
   / Rear tire stance adjustment #11
That's weird. I didn't pay extra for the tires
I thought that is the case these days... they just have not updated the manual. Do you know if that is true with turf tires too???
   / Rear tire stance adjustment #12
teg - what are you saying? That the rims used for R4 tires(industrial) do not have the provision to reverse the inner dish?? Or that R4 rims do not have separate inner dish and outer rim??
   / Rear tire stance adjustment #13
For his (and my L2800) "economy" tractors!!! It's one unit, look at his first photo, the "inner dish" is welded to the outer section. It's a solid wheel. My friend has R4 on a Grand L and his wheel is two sections, inner and outer parts that can be adjusted.
EDIT: you can see the welds in both photos...
   / Rear tire stance adjustment #14
Yes, now I see what you mean. I've been told my rims (R1 rims???) are not the correct design to support the outer bead on a R4 tire. If I wanted to go to R4 tires I would also have to get new rims. I thought about at one time but after checking the R1's are best for my needs.
   / Rear tire stance adjustment #15
Those welded rims are same as on my B26. They are at their widest and ONLY position. If you tried reversing them, the tires would hit the fenders. Only way to widen is with spacers OR replacement of the rims with two piece rims. I don't know if something like that is even available for these tractors.
METAL STORAGE RACK (A52708)
METAL STORAGE RACK...
2021 John Deere HPX815E Gator 4x4 Utility Cart (A56857)
2021 John Deere...
BUSH HOG DISC (A58214)
2025 GPS Trailer (A56859)
2025 GPS Trailer...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
2017 Ford F-150 Ext. Cab Pickup Truck (A55973)
2017 Ford F-150...
