Rear remote / Valve body
   / Rear remote / Valve body
OK I figured it out. The local tractor mechanic is familiar with this part and set up. P= Pressure to the spool valve. R= return from the spool valve. T=tank/ plumb it out from the block and go back to the tank for an overflow situation. He said that landscapers use this set up alot to power up a set of valves to run specialty equipment for fine adjustments for grading/ slope etc. He said it is an acceptable workaround for rear remotes and allows for finer adjustments. I'll let everyone know how it works out. Thanks for all the help.
1645 (A58375)
1645 (A58375)
2005 International 7600 Dump Truck, VIN # 1HTWYAHT15J055083 (A57453)
2005 International...
2009 MULTIQUIP 25KW GENERATOR (A58216)
2009 MULTIQUIP...
2011 Ford Edge AWD SUV (A56859)
2011 Ford Edge AWD...
2018 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2018 MQ POWER...
Automatic Tire Changer (New/Unused) (A59225)
Automatic Tire...
