Oil & Fuel Rear end fluid on L4310
   / Rear end fluid on L4310 #1
jcri
Alexandria KY
Kubota L4310HST
Hello all,
Another question. Until I’m able to find manuals I’m looking for some help. On this tractor, the rear end show signs of some leaking and the site glass appears to be too clouded to see anything inside. This is the HST model, so I assume that this is Hydraulic oil. Can anyone advise if there is something like a check bolt for fluid level or something else other than the site glass. I plan on changing this within the next couple of days but I’d like to be able to verify that it has enough fluid in it right now. Any suggestions?
   / Rear end fluid on L4310 #2
There is not a check bolt. You could pop out the sight glass and fill till fluid comes out. I replaced the sight glass on my 3410 and it's a 2 minute job.
Thank you. I did t realize the site glass was so easy to replace. I’ll replace it.
2013 Chevrolet Express 3500 Passenger Van (A55973)
2013 Chevrolet...
PENDING SELLER CONFIRMATIONS (A58018)
PENDING SELLER...
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 Land Rover Range Rover Sport 4X4 SUV (A55853)
2013 Land Rover...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A56859)
2004 Fleetwood...
