Grading Rear blade size
   / Rear blade size #1
bowhunter3030
Collinsville, IL.
Kubota Grand L4060hstc & Kubota B2601
After having my tractor for almost 3 weeks now, I just noticed that my dealer gave me the Rhino 500 rear blade instead of the 300. It weights 110 more pounds than the 300. It is much better than the 300, as it has more adjustments and is 6' instead of 5'. My question, is this to big for my B3030?
   / Rear blade size #2
NO it should not be to big for your tractor. i have a 6' rear blade on my B2400 and it does fine, i would have preferd 5' but it came with the tractor. the only thing i don't like about the 6' on mine is i can't swivel it 180 deg as the top corner hits my 3 pt. lift arms. but i don' think that would be a problem with your larger tractor.
   / Rear blade size #3
It should handle it fine. You tractor will lift 4.4 times what the larger blade weights and your tractor weights 4.8 times what the blade does.
2016 Isuzu NPR-HD 24ft Box Truck (A50323)
2016 Isuzu NPR-HD...
2015 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51242)
2015 CATERPILLAR...
Detach Trailer (A50514)
Detach Trailer...
CATERPILLAR D6R XL CRAWLER DOZER (A51406)
CATERPILLAR D6R XL...
2016 Ford Explorer...
2013 Ford F-150 Pickup Truck (A50323)
2013 Ford F-150...
