rear 3pt arms drop overnight?
   / rear 3pt arms drop overnight? #1
Deezil
PNW
2022 Branson 2515H
Is that normal? My buddies 3520 doesnt, but my 2515H will drop to the floor overnight. Does yours?
   / rear 3pt arms drop overnight? #2
I drop the 3pt and loader for safety when I park the tractor, so I've never tested it. Most valves leak a little so it's not unusual for them to leak down over night.
   / rear 3pt arms drop overnight? #3
this is usually an indicator of air entering the system somehow, generally its at a fitting that is loose and will need to be tightened down so i would start by having you check those hose connection that feed the 3 point lift, you should be able to see them clearly on the top of the 3 point hydraulic top case that the upper arms attach to, does you front end loader do the same thing?
It has 12 hours on it, and I got it at 1.9hrs and its done that since new. No, Front loader will stay up. No leaks of fluid anywhere. Buddies 3520 doesnt leak down.
   / rear 3pt arms drop overnight? #5
you can have a small air leak with no visible fluid. Just because its new doesn't mean you don't have a loose connection somewhere. Happens all the time, won't hurt to check
   / rear 3pt arms drop overnight? #7
I don't have a Branson, but my 3 point has leaked off overnight for years.
Never caused an issue while using the tractor so it makes no difference to me.
   / rear 3pt arms drop overnight? #8
My loader will drop and curl down if setting for an extended time. My three point will stay up forever, even with a load. However if it dropped after setting all night, I wouldn't be overly concerned. My old Ferguson has done that for the last 60 years.
   / rear 3pt arms drop overnight? #9
My 3 pt also stays up pretty much forever. I'm sure it drops maybe 1 or 2 mm but it's even noticeable. The top link and remote valve only drops a little bit but that related to an used cylinder for the top link that has a tiny rod seal leak.
   / rear 3pt arms drop overnight? #10
It's interesting, the different experiences people have with regards to 3 point drop; I've never experienced it myself, but it's prevalent enough that I've been told so far back as I can remember to lower 3 point implements when parking.
2015 Ottawa Yard Spotter Truck - Cummins Diesel, Allison 6-Speed, Hydraulic Air Fifth Wheel (A51039)
2015 Ottawa Yard...
2021 Delta Redirective Crash Cushion 75000 (A49461)
2021 Delta...
2011 MAMMOTH UTILITY (A50854)
2011 MAMMOTH...
2020 FREIGHTLINER 26FT BOX TRUCK (A51219)
2020 FREIGHTLINER...
3HP Electric Fans (A50854)
3HP Electric Fans...
2011 Nissan Titan SV 4x4 Crew Cab Pickup Truck (A50323)
2011 Nissan Titan...
