Re: Installation of Winter heater for coolant
   / Re: Installation of Winter heater for coolant #1
dmedalen
Cub Cadet LX450TL
I have a new Cub Cadet TL450LX with a 4-cyl. Yanmar engine. I love it! I would like to mount a circulating coolant heater on it but I am not sure if I will be able to purchase metric-threaded hose fittings to mount on the engine block and thermostat housing. Does anyone have any suggestions??? I am hesitant to mount a heater in the 1" lower radiator hose as the closed thermostat will likely severely restrict the circulation of the coolant. Or have any of you out there found a rad hose heater more than adequate??? I would welcome any suggestions.
   / Re: Installation of Winter heater for coolant #2
I think you mean LX 450? If so you probably have the Yanmar 4tnv88 engine, same as mine.
Here is the screw-in block heater for the 4tnv88: ZeroStart - 310-0003 - Freeze Plug Engine Heater , 400W 120V
Its not metric and it works very well. I plug mine in about an hour before starting it in the winter. You'll want to heat the plug with a propane torch before attempting to unthread it. After heating the plug I used a 1/2 inch impact gun with light taps on the trigger until I saw the plug start to turn, then backed it out from there with a breaker bar. If you're quick you can swap out the plug with the block heater and not loose more than 6-8 ounces of coolant. If you attempt this, don't forget to put teflon tape on the threads of the block heater before installing it. Good luck!
More info here: http://www.tractorbynet.com/forums/yanmar/258437-4tnv88-block-heater.html
Yes, you are very correct. It is a 2011 LX450TL. Thank you. (Great tractor so far). And I will search out the heater. Thanks again.
2025 AGT YC-32G Saw Mill (A53317)
2025 AGT YC-32G...
2025 YOU-380 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
2025 YOU-380 Mini...
2022 Carry-On 5'x8' Trailer (A53316)
2022 Carry-On...
(2) SHOP VACS ON PALLET (A58374)
(2) SHOP VACS ON...
FOREST CITY 8R SUB / BED (A52708)
FOREST CITY 8R SUB...
2025 GPS Trailer (A56857)
2025 GPS Trailer...
