RC2048 really smooth
   / RC2048 really smooth #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
I removed the blades and "sharpened" them on the Frontier RC2048 bush hog (blades look something like Rocky Marciano's face after a bad fight). The nuts weren't particularly tight when I loosened them with my 6 ft piece of pipe on my 3/4 inch plain handle. I was careful in putting the bolts back to get them into the detents properly after using a file a little bit on the detent recesses. (The bolts have a protrustion that goes into detents that keep them from rotating.) Going back on, the nuts didn't need much movement after snugging with ratchet wrench handle followed with plain handle and 6 ft pipe to get them as tight as I could push (my 420 ft lb, e.g. maybe 70 # applied to my 6 foot pipe).
I always run the thing a bit with the trail wheel off and retorque later. So, I took it down and hit some briar patches. Really smooth this year.
Wondering if I should replace the nuts and lock nuts?
Ralph
   / RC2048 really smooth #2
It sounds like you did everything right. Some recommend replacing the blade bolts with every new blade change. I replace when damaged (part of head chipped off, or the area the blade swings on is worn/grooved)
If meant should you replace the blade nuts WITH locknuts, I see no need.
(INOP) CATERPILLAR 416B BACKHOE (A50459)
(INOP) CATERPILLAR...
Parker Chipper Shredder Vacuum (A48083)
Parker Chipper...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2018 Terex RL4 4000W Towable Light Tower (A49461)
2018 Terex RL4...
UNUSED Black Outdoor Patio Fabric Screen Cover (A50860)
UNUSED Black...
Headache Rack (A50860)
