Rail roads and their tracks.
   / Rail roads and their tracks. #1,791
I'm curious what kind of power the generator or alternator on the locomotive put out, as most locomotives of that time had only DC generators for traction, and another smaller generator that provided power to run electrical control systems and charge the batteries.
Unless it did have AC traction motors and was able to supply 60Hz AC at a suitable voltage.
I didn't see any cables leading off the locomotive to distribute the power.
I found some discussions where it was a M420 and that model is AC. M420R is DC.
It's rated at 1.49MW.
When I had to participate in connecting auxiliary generators to our printing pressroom during a major power outage, it was 3-phases +ground. They had to use 3 cables for each phase and ground, (12 cables total), because if they used a single cable for each phase, they would be too thick and too heavy to move, and too large to connect to the busses. The cables were about 1-1.25" in diameter as I recall. They were stranded cables and very flexible. We used one 0.75MW generator and it would only let our press run around 20% before trippping. So they brought in anther 1MW generator and hooked it in parallel to give a total of 1.75MW (more than the locomotive), and that allowed us to run around 60% before tripping.
So based on that experience, and that locomotive only putting out 1.49MW, it could run lights, HVAC and things like that in several buildings, but it couldn't run something like industrial equipment that pulled large power.
I think overall, the experiment cost them more in repairs to the road and locomotive, etc. had they just brought in large generators.
Maybe it was all that was available at the time, so you do what you gotta do.
   / Rail roads and their tracks. #1,792
Speaking of locomotives and gensets, back in 73 or 74 during the oil embargo, Miles Labs in Elkhart bought and installed three EMD 20 cylinder 645 series gensets behind the citrus plant. We did the grading for the slab where they were set up while we were doing some other sewer work on the site. I was there when one was delivered, unloaded and set in place. A couple of weeks later we were back doing some final grading work and they were test running one of the units. I walked over and talked to one of the installation contractors about the gensets. If I remeber correctly, they were 3 MW each, 2 would run the whole complex, with one for a spare. Those were impressive units when running at full capacity on a test load, made the ground shake.
   / Rail roads and their tracks. #1,794
The EMD 645’s I worked with once were 1.5MW each, 1.7MW if turbos.
   / Rail roads and their tracks. #1,795
EMD testing
A professionally made video of the 4014 and the 844 on there way to Ogden Utah on the 4014's maiden voyage after its rebuild. They did include lots of good info with it..
   / Rail roads and their tracks. #1,797
We hauled some EMDs out of a locomotive scrapyard in Homewood, IL some years ago. A 16 cylinder 645 engine and alternator were over 45,000#.
   / Rail roads and their tracks. #1,798
My grandfather was a Gandy Dancer on theNew Haven Lin before WWII. SAID IT WAS SOME OF THE HARDEST WORK HE EVER DID IN HIS LIFE. He later was a foundryman.
   / Rail roads and their tracks. #1,799
   / Rail roads and their tracks. #1,800
By coincidence, I was at Steamtown National Park over the weekend and took these shots of their recently restored #4012 "BigBoy":
Definitely impressive when seen in person.
There is talk of further restoration to full running condition but it will cost several million $$.
2015 Ford Explorer AWD SUV (A41185)
2015 Ford Explorer...
2005 Ford F-150 Ext. Cab Pickup Truck (A41185)
2005 Ford F-150...
2021 Bobcat 78in Hydraulic Tiller Skid Steer Attachment (A41182)
2021 Bobcat 78in...
Hedge Line Posts (A39855)
Hedge Line Posts...
NEW FLAND FL45 RUBBER TIRED LOADER powered by gas engine, 13.5hp, equipped with OROPS, 39in. GP (A40023)
NEW FLAND FL45...
NEW 1" AIR IMPACT WRENCH 1900 FT/ LB NEW SUPPORT EQUIPMENT (A40023)
NEW 1" AIR IMPACT...
