Questions: Usefulness of a Compact Tractor
   / Questions: Usefulness of a Compact Tractor #11
Purchase it or always regret letting it slip past you. It will also hold it's value as an investment better than many stock market purchases. Appears to be pretty much a mate to a JD 2305.
Kubota BX24 Engine:
Kubota 0.9L 3-cyl diesel
Capacity:
Fuel: 6.6 gal [25.0 L]
3-Point Hitch:
Rear Type: I
Rear lift (at ends): 992 lbs [449 kg]
Rear lift (at 24"/610mm): 661 lbs [299 kg]
Power Take-off (PTO):
Rear PTO: independent
Rear RPMs: 540
Engine RPMs: 540@3068
Mid PTO: independent
Mid RPMs: 2500
Engine RPMs: 2500@3125
Dimensions & Tires:
Weight: 1,542 lbs [699 kg]
Kubota BX24 Power:
Engine (gross): 23 hp [17.2 kW]
PTO (claimed): 17.7 hp [13.2 kW]
Mechanical:
Chassis: 4x4 MFWD 4WD
Differential lock: standard
Steering: hydrostatic power
Brakes: wet disc
Cab: Two-post ROPS.
Hydraulics:
Type: open center
Total flow: 6.3 gpm [23.8 lpm]
Electrical:
Ground: negative
Battery:
Volts: 12
Ag front: 18x8.5-10
Ag rear: 26x12-12
Lawn/turf front: 18x8.5-10
Lawn/turf rear: 26x12.00-12
2005 EAST 45' WALKING FLOOR TRAILER (A54756)
2005 EAST 45'...
2023 FORD F-250 (A58214)
2023 FORD F-250...
2003 Big Tex 10PI...
2017 Freightliner M2 106 24ft Box Truck (A56858)
2017 Freightliner...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
2014 Peterbilt 388 T/A Wet Kit Sleeper Cab Truck Tractor (A55973)
2014 Peterbilt 388...
