Questions on Woods RD7200 finish mower pins
   / Questions on Woods RD7200 finish mower pins #1
Gary_in_Indiana
Elite Member
Fort Wayne, IN
John Deere 4200 MFWD HST w/ JD 420 FEL w/ 61" loader bucket & toothbar & JD 37 BH w/ 12" bucket
The lift pins on my Woods RD7200 finish mower are on plates which raid and lower for no reason obvious to me. Any ideas as to why they're designed that way? Just curious. /forums/images/graemlins/smile.gif
   / Questions on Woods RD7200 finish mower pins #2
I have the same mower. I have wondered why the mountings can go up and down also. The only thing I can think of is that it's easier to connect to the lower 3pt arms.
   / Questions on Woods RD7200 finish mower pins #3
I had a Woods RD6000 RFM...this spring I tried to hook it up after not using it for about 8 months [grass grew very little last year] and it was hard as heck to get my lower link arms low enough to hook up.
After struggling more than I like to, getting a 4x4 for leverage and so on, I happened to lift one of those plates...imagine my surprise when hooking that side [second one, naturally] became a piece of cake... /forums/images/graemlins/blush.gif
I think RichNJKubota hit the nail on the head... /forums/images/graemlins/blush.gif
   / Questions on Woods RD7200 finish mower pins #4
My Bush Hog finish mower was the same way; presumably for the same reasons. I would speculate that ease of connection, as mentioned by the others, is one reason. Of course, with wheels on all 4 corners, I mowed with the 3-point in the lowest (float) position, but guess if someone doesn't do that, it would still allow the mower to move up and down a bit, independently of the tractor, to follow the contours of the terrain, and no matter what the height the 3-point is set at, it allows the mower to tilt side to side a bit; something that should not happen if the pins were on a rigid mount.
   / Questions on Woods RD7200 finish mower pins #5
Like Bird says it is for flex so mower follows contours.
Thanks, guys. That was the only think that made any sense to me. It sure doesn't make it any easier to attach with the quick hitch, though. /forums/images/graemlins/crazy.gif /forums/images/graemlins/smile.gif
   / Questions on Woods RD7200 finish mower pins #7
My boss has a 7' landpride RFM and has a quick-hitch to use but doesn't on the mower because of the moving lower links.
It is so easy to hook up w/ the floating lower links and u still have to hook up the pto.
Because of the swinging top link the quick-hitch will not let it work.
Portable Restroom (A54865)
Portable Restroom...
UNUSED 1RANCH 1RETC HYD THUMB CLAMP (A57193)
UNUSED 1RANCH...
2021 VOLVO VNL740 TANDEM AXLE MID ROOF SLEEPER TRUCK (A57880)
2021 VOLVO VNL740...
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55852)
Unused SDJ-4000...
2025 GIYI GY-ZWB Hydraulic Backhoe Arm with Tooth Bucket Mini Skid Steer Attachment (A56857)
2025 GIYI GY-ZWB...
UNUSED SDLANCH SDLC1220-12' X 20' CARPORT (A57193)
UNUSED SDLANCH...
