questions during hydraulic fluid change
   / questions during hydraulic fluid change #1
unclesalty
Bronze Member
Hudson Florida
09 ct-225 w/loader
Well its time for my hydro maintenance. The short story..Dipstick said the level was good. I drained from all 3 plugs and only got 5 gallons out after at least an hour draining. I filled the 1 filter up and screwed them both on and poured in the new oil. I was just able to get 5 gals back in and the dipstick shows slightly over full. The manual says it should take 8 gals of fluid. should I be worried? (the loader was down all hydraulics were retracted). Im kind of tempted
to run it up to temp and drain and fill again esp if there is still 3 gallons still inside. The old fluid was nasty. Tractor was at 700 hours but its 9 year old fluid so I changed it out early.
   / questions during hydraulic fluid change #2
did you fill your filter?? if not then thats why you are over full . run it a few minutes then let it set and recheck
   / questions during hydraulic fluid change #3
If you have a mid pto you have 4 drain plugs, one on the pto case.
   / questions during hydraulic fluid change #4
Even if your cylinders are retracted they still hold a fair amount of oil.
duh I had assumed the rear pto had replaced the 3rd plug...Looks like I'm off to get another bucket of fluid.
2011 FREIGHTLINER M2 TANDEM AXLE FLATBED TRUCK (A51222)
2011 FREIGHTLINER...
1998 Ford F800 Water truck (A49461)
1998 Ford F800...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
2014 KALMAR 4X2 YARD DOG (A50854)
2014 KALMAR 4X2...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A48082)
2016 Toro...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
