Question for M4800 Owners
   / Question for M4800 Owners #1
Bob_Young
Veteran Member
North of the Fingerlakes - NY
Ford 4000; Ford 2000(both 3cyl.);JD40; 2004 Kubota L4300; 2006 Kubota B7610; new 2007 Kubota MX5000
In the Implement Limitations section of the Operator's Manual, what is the listed Max. weight and cutting width for a Rotary-Cutter type Mower?
The dealer has an M4800SU 4WD that looks interesting, but it has to be able to handle 1200# mower.
Thanks.
Bob
   / Question for M4800 Owners #2
I don't have an M4800SU but on its spec sheet it lists 3310 lb lifting capacity 24" beyond the hitch pins, with 4200 lb at the pins. By the moment law that would calculate at 2840 lb 42" behind the pins (center of a 7' rotary). Being a 2wd tractor it would want front suitcase weights but should handle a 7' rotary ok.
   / Question for M4800 Owners #3
I have a 4700 SU which is basically the same tractor with a few less bells and whistles. I use a 7' HD rotary which is a heavy beast with no problems at all. Mine is 4WD. The 4800 is a stout tractor.
d
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
American Sanders Super 7R Electric Wood Floor Edger (A49461)
American Sanders...
Bad Boy Electric Cart (A50860)
Bad Boy Electric...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A51039)
Neckover GL24-2-7K...
2007 John Deere TX 4x2 Utility Gator (A49346)
2007 John Deere TX...
