wdchyd
Elite Member
Having two control valves in series without PB and both actuated to full relief will double the pressures of both control valves.
The diagram and video show only a few hundred psi to show theory, but using control valves with thousands of psi is dangerous.
I personally was called in to troubleshoot a faulty system at a wood chip manufacturer, their Gresen SP monoblock valves (without BP plugs) had a catastrophic housing rupture on an upstream control valve, the operator had a bungy cord tied on a valve handle on a downstream valve, he operated the upstream valve and the housing split and shot oil into the cab of his truck.
So, this does apply to this thread topic as the OP was asking why it’s needed.
