Question about going shares on hay
   / Question about going shares on hay #1
archerm3
Midwest
Bobcat CT230
I got a guy that wants to disk and replant 6 ac of my land for hay. He is going to do all the disking, planting oats and alfalfa. at the end of the year we will split bales 50/50. Would I be expected to pay for any fertilizer throughout the year? He is paying for the seeds.
   / Question about going shares on hay #2
I would think it is in his best interest to have a good crop. He is giving you half of the crop in exchange for the use of the land and the right to plant and harvest the crop. Fertilizer cost, unless you agree to it, should be his cost. If you are not sure then have it clarified, you do not want a conflict at harvest time. Communication is a very good thing. :)
   / Question about going shares on hay #3
"Here" if you supply the land and no inputs or labor or machinery, you are entitled to about 1/3 of the crop. Who is cutting and baling the hay? I'll assume he is. If you require a 50-50 spilit of the crop and want to be fair, you need to up the ante substantially on your end. You should buy the fertilizer and lime, and consider buying the seed. Remember, if he goes away, he can't take the crop, and he is supplying the machinery, $3.00 + fuel, labor and all the risk. As you describe it, you are supplying land, and sitting on the porch.
   / Question about going shares on hay #4
Sounds to me he's offering a very good deal for you. I used to have a neighbor here that would cut, rake and bale my place and it was on a common split of 70/30. He got 70% of the hay and I got 30%. He did have the larger expense since I wasn't spraying or fertilizing the fields.
Thanks for the replies.
Rick, yes, it is as you describe. I would rather take less shares than have to ante up cash for fertilizer and such, we will see what the guy says next time I talk to him.
   / Question about going shares on hay #6
What ever the two of you agree on is fine.
Keep in mind hay is about the only crop that removes 100% of what is grown from the land so it is very hard on the land. The good thing is there is not top soil washing away. The cost to buy or rent land today makes hay very expensive often times.
   / Question about going shares on hay #7
Glad to hear it. A deal has to work out for both parties to be successful. It is a cleaner deal if you supply none of the inputs and take a fair share for supplying the land.
2014 VOLVO VHD (A50854)
2014 VOLVO VHD...
2019 Ford F550 4x4 Bucket Truck with Altec AT41 Boom - 46FT Working Height and Jib Winch (A51039)
2019 Ford F550 4x4...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
Fifth wheel multi use trailer. (A51039)
Fifth wheel multi...
2008 Ford Escape XLT SUV (A48082)
2008 Ford Escape...
2013 GMC Sierra 2500HD 4WD Pickup Truck (A50860)
2013 GMC Sierra...
