Putting a Bradco 11HD Backhoe on a Kioti DS4510?
   / Putting a Bradco 11HD Backhoe on a Kioti DS4510? #1
Ithaca, NY
Kioti DS4510
Looking for some input-Bradco states that this set up should work in terms of hydraulic flow and size of tractor, but the hoe seems a bit big for a tractor that only weighs 3500#. Recommended flow is 11-15 GPM, Kioti putting out 13 GPM. Thoughts or advice would help.
Also, Bradco does not make a sub-frame mount to match any Kioti tractor, so I will be modifying the original sub-frame mount for the Kioti hoe.
   / Putting a Bradco 11HD Backhoe on a Kioti DS4510? #2
That's way more of a backhoe than I would want on any tractor of that size. The stresses that can be transferred from the backhoe to the tractor chassis are my primary concern. Something like a Bradco 508 or the equivalent would be more appropriate.
   / Putting a Bradco 11HD Backhoe on a Kioti DS4510? #3
I made mounts for a Bradco 611 to my New Holland TC 55 DA. The hoe is built super strong and may be a bit too much for the tractor but operating it in a manner it was designed for it works out beautiful. My used hoe was mounted on a Case 1840 skid steer. It was in perfect condition because it was way more machine ( and heavier ) than the skid steer could handle. When I priced a mounting system ( hoe and tractor mount ) I found not only was it more than I paid for the back hoe but it did not have available a sub frame mount that connected the front frame rail. For the price of the shipping ( quoted $350.00 for both mounts ) I bought steel and fabricated a mount I felt that incorporated a proper mounting system. Its not a quick tach but it can be mounted or taken off in fifteen minutes which is not a problem for me.
   / Putting a Bradco 11HD Backhoe on a Kioti DS4510? #4
Somewhere here at TBN is another fellow who put a Bradco 611 on his TC55 and fabricated up his own full length frame mounts. He did a truely fantastic job, and also posted pictures.
I also agree with Rick B whole heartly. That's a big powerful hoe for that size Kioti....
Joes Corvette did it also.
http://www.tractorbynet.com/forums/build-yourself/98777-back-hoe-mount-bradco-611-a.html
Here's the link to a Ford 545 Industrial tractor and a Bradco 611.
http://www.tractorbynet.com/forums/new-holland-owning-operating/117867-added-bradco-611-545d.html
   / Putting a Bradco 11HD Backhoe on a Kioti DS4510? #5
I would be very careful about the mounting frame. If you damage the tractor, Kioti can say it was the hoe & mounting frame fault and you have no recourse (on the basis it is a Kioti issue).
I only say this b/c there's a thread in the Attachment or Operating Kioti forum where Kioti is pointing the finger at the hoe manufacturer (Woods I think?) b/c it isn't a Kioti brand hoe. I haven't heard the outcome but thought I'd mention it as something to keep in mind.
Good luck!!!
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2011 Chevrolet Impala Sedan (A55853)
2011 Chevrolet...
2021 Deere 333G (A53317)
2021 Deere 333G...
1993 FORD F-350XL SINGLE CAB FLATBED TRUCK (A51406)
1993 FORD F-350XL...
2011 Audi Sedan (A56859)
2011 Audi Sedan...
4 Cubic Yard Dumpster (A55851)
4 Cubic Yard...
