Put my LT1050 to bed for the winter.
   / Put my LT1050 to bed for the winter. #1
Rickstir
Hard by the Elk Fork of the Salt River, Missouri
2009 Mahindra 4110
Up here in North East Missouri, grass cutting season is over. So with the help of a buddy we:
Filled the tank with fresh gas and put in Stay-bil and a shot of Heet. Ran the engine for five minutes to run the additives into the engine and warm up the oil.
Changed the oil and filter, clean the air cleaner and oiled the filter.
Pulled the mower deck out. Greased the tension pulley on top, boy I wish they had an access hole for that. Turned it over and scrapped the caked on grass down to the metal. Took out the clean-out fittings as they were clogged. Have to get two new ones. Greased the three blade spindles. Checked the blades, they look good for a while longer.
Greased the front wheels and spindles as well as the go pedal.
Pulled he plugs and put a tablespoon of oil in the cylinders and cranked it a few times, replaced the plugs with new ones gapped to .030. Put the plug wires back on.
Finally put her on a trickle charger and patted her hood for a good trouble-free mowing season.
Love this mower because it makes mowing a nice experience. I used to love mowing and running my Mahindra 4110 with a Bush Hog 84 inch finishing mower because I could just drift off and forget about work and such. Now I am retired, what am I going to forget about now?:p
   / Put my LT1050 to bed for the winter. #2
It'll be 50 here tomorrow so I'll get probably my last cutting in. For me winterizing is that the deck gets a through under/over cleaning. Treated fuel is topped off and selected areas get painted over with waste oil. Finally
moth balls are liberally dispensed to keep mice at bay...and I do that again sometime over the winter.
   / Put my LT1050 to bed for the winter. #3
Winterized my Craftsman riding mower last week. Hopefully, I won't need to use it until Spring. I probably can get by just using the Stihl weed eater for certain high growth areas. :)
JOHN DEERE 450H CRAWLER DOZER (A51406)
JOHN DEERE 450H...
2012 GMC Acadia SLT1 SUV (A48082)
2012 GMC Acadia...
Informational Lot - Financing (A51039)
Informational Lot...
Hay Fork (A50860)
Hay Fork (A50860)
2012 MACK GU713 DUMP TRUCK (A50459)
2012 MACK GU713...
2018 Chevrolet Camaro 1LT Coupe (A48082)
2018 Chevrolet...
