Pushing back the woods
   / Pushing back the woods #11
I have a DR brush mower,,,go with the brush hog. Dr works fine but only has a 26" blade, so takes lots of time and Blackberry bushes like to grab your arms and face if you aren't careful.
The only reason I use it is I don't have a tractor yet. I think you can buy one heck of a brush hog for $2,000, which is what the 10.5 DR costs.
   / Pushing back the woods #12
rwarner
This is the BEST thing I have found for removing saplings up to about 4 inches. It gets the tree, root and all and there's less ground disturbance then pushing the trees over and "flipping" them out of the hole with the FEL.
I built this one myself to mount on the 3pt (added the rest of the "fingers" just this week) but it's based on the Brush Brute. I think the Brush Brute mounts on the FEL but you have to remove the bucket to mount it.
   / Pushing back the woods #13
Now I wonder how hard it would be to adapt that for pulling T-Posts? Or do you think it would 'grab' a t-post as is, and pull it w/o bending it? Maybe adding a flip across bar to lock onto the nubs of the t-post?
<P ID="edit"><FONT SIZE=-1>Edited by scruffy on 04/09/01 00:10 AM (server time).</FONT></P>
   / Pushing back the woods #14
scruffy
I hadn't thought about the Tposts, but I have some that have to go and I'll try pulling them with this rig and let you know how it works.
   / Pushing back the woods #15
FANTASTIC!! Looks GREAT! I'm gunna fire up the welder this weekend!
Thanks for the idea!
Steve
   / Pushing back the woods #16
Ditto that!!! How long did you make the teeth and what are the gaps at the open ends???
Thanks in advance
Gordon
   / Pushing back the woods #17
TraderMark, how long are the fingers, spacing, and how are they made... Thanks, I will have a local shop get started this week...
   / Pushing back the woods #18
I'll do my best to give all the specs on the first try, but if I don't.... just holler !! /w3tcompact/icons/laugh.gif
The crossbar and the upright for the top link are made from 2X3X1/2 wall tubing.
The fingers are 15 inches total length (that leaves 12 inches protruding from the crossbar) and are made of 1/2X3 flatbar.
I left 1/2 inch in the center of each finger and tapered them back 11 inches. Each finger has a piece of 3/8X2 flatbar welded edge ways and welded to the crossbar to prevent the fingers from bending.
   / Pushing back the woods #19
This might be a really dumb question but... have any of you guys that cut these 1-3" dia. saplings ever punctured or cut a tire by driving over the stems in future passes or while mowing a month or three later? I would think they would be pretty rigid already when they are that big... or doesn't it leave the stems very sharp when they are cut off? Those tires are expensive! /w3tcompact/icons/shocked.gif I may be faced with this situation in the future & would hate to be faced with big tire repair bills.
Troy
   / Pushing back the woods #20
<font color=blue>have any of you guys that cut these 1-3" dia. saplings ever punctured or cut a tire by driving over the stems in future passes or while mowing a month or three later?</font color=blue>
No, I haven't, but my neighbor sure did; on a tractor with 38" wheels and I helped him fix the flat; not a lot of fun, especially since he didn't know until he did it that his tires were filled with calcium.
Bird
RING 2 STARTS HERE @ 9:15 AM (A58375)
RING 2 STARTS HERE...
2013 KENWORTH T680 TRI AXLE SLEEPER TRUCK (A58018)
2013 KENWORTH T680...
2015 CATERPILLAR  XQ30 GENERATOR (A58214)
2015 CATERPILLAR...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A55302)
Kubota SVL65-2...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
Dewalt D28755 14" Cut-Off Machine (A59076)
Dewalt D28755 14"...
