Rotary Cutter Purpose of the Tail wheel on a rotary cutter
   / Purpose of the Tail wheel on a rotary cutter #1
brandon327
My father in law and i are in disagreement on the purpose and use of the tailwheel on a rotary cutter. What is ya'll opinion on the use of the tail wheel?
   / Purpose of the Tail wheel on a rotary cutter #2
You go first.
   / Purpose of the Tail wheel on a rotary cutter #3
I always thought it was to support the rear of the mower at a specific height for a more even cut. With the mower deck weight resting on the wheel, it also takes some strain off the 3pt hitch, not that it shouldn't be able to handle it.
   / Purpose of the Tail wheel on a rotary cutter #4
The tailwheel sets the cutting height. The lower three point links carry the front of the cutter and establish the pitch and yaw of the deck. The toplink supports the cutter in transport position and helps carry the rear of the cutter over low spots, helping to lessen scalping on uneven terrain.
   / Purpose of the Tail wheel on a rotary cutter #5
The tail wheel and two lift arms provide three-point suppport for the deck while the blades are spinning. The tail wheel is also used to ballpark the cutting height. Once established, the two lift arms are subsequently adjusted to approximate that height. Typically the final lift arm cutting height adjustment should leave the deck at least one inch lower in the front than in the rear to facilitate discharge.
//greg//
   / Purpose of the Tail wheel on a rotary cutter #6
The tail wheel mainly for uneven ground. If it wasn't there, backing up to or comming down a hill, the rear of the deck would dig into the ground. And when going up hill, it takes the weight off the 3PH to allow you to steer and not do a backflip up a steep grade.
   / Purpose of the Tail wheel on a rotary cutter #8
What does rofl stand for?
And if you use a chain for top link,it will stay on the ground a lot more.
   / Purpose of the Tail wheel on a rotary cutter #9
ROLLING ON THE FLOOR LAUGHING
or a toggle that should have been supplied with the mower so it floats behind the tractor.
tom
   / Purpose of the Tail wheel on a rotary cutter #10
Thanks,not up on this lingo,but have rolled on floors before:)
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A55314)
2023 Kubota...
BRADCO HP600 COLD PLANER (A52707)
BRADCO HP600 COLD...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
Honda Pioneer SXS700 4X4 Utility Cart (A55787)
Honda Pioneer...
2020 Club Car Onward HP Li ION Electric Cart. (A53424)
2020 Club Car...
2015 Komatsu PC138 (A47477)
2015 Komatsu PC138...
