Purchasing Help on used John Deere 2520
   / Purchasing Help on used John Deere 2520 #1
Ed G
Northeast PA
(Soon to be) 2520, 200cx, 46 BH, 727A ZTM, Gator, LX279
As a new member to this forum this is my very first post....I want to say up front thank you all for the info here - it has been very helpful; and I also want to apologize in advance for what is a long first post, as well as for what may be "rookie" questions!
I just sold my JD 790 w/#70FEL and #7BH (I was very pleased with the 790, but I need to get a tractor with a hydro trans to accommodate some recent family handicap issues). I need the tractor for general work/landscaping around my farm and house, plowing snow, and maintaining the property. I already have a Gator and a 727 for mowing, so I will not really need to mow with the new tractor. My wife and father-in-law (who is somewhat handicapped and also owns a JD 4200 w/FEL and BH) will also drive this.
I have two separate used tractors I am looking at:
#1 - Used 2006 2520 w/77hrs, 200x FEL and 46BH for $16,500...this is my first choice b/c it has a backhoe and lower hours (I did confirm through JD that the tractor is free & clear financially)
#2 - Used 2005 4310 w/298 hrs, 430FEL and 60" mower deck for $16,500....this may be a bit larger than I really need (my neighbor has one), and I would need to purchase a backhoe (I would sell the 60" mower deck).
I would like any feedback/reccomendations you all may have...some of my questions/concerns are:
- How will the FEL and BH power of the 2520 compare to the 790 I have now? Based on the specs I have reviewed is should be MORE powerful...
- How will the 2520 compare to the overall power of the 4200 my FIL has now?
- Have there been any significant design changes in the 2520 since 2006 (e.g., rear wheel spacing)?
- Is the power of the 200x the same as the 200cx FEL (I do understand the 200x is not the quick-tatch).
- Any guesses as to how much a backhoe would be for a 4310 (installed)?
- Any guesses as to how much $$ I could get for a used 60" mower deck?
Any guidance or recommendations you can add??
Just a side note - I have been working with two separate JD dealers through this process both of whom have been exceptionally helpful and responsive - even after they knew I had mad the decision to purchase a used tractor.
   / Purchasing Help on used John Deere 2520 #2
Welcome to TBN:D
I will take my best shot:
It will be stronger, especially the loader. The 70 loader was very weak.
The 4200 was often considered underpowered at 28HP because of the size of it, I think the 2520 will "feel" stronger.
Just to the 3PH lower arms, they were re-designed because of tire rubbing problems, lots of threads about this in the JD forum.
It share's the same specs as the CX, and the X can be upgraded by buying the extra parts.
$7000.00 is a very close estimate.
$1000 to $1500 average, $2000 if you are real lucky.
Thanks Kenny....very helpful and much appreciated!!
Sorry - I just realized this belongs in the JD forum...I will re-post it there (since I do not think I can "move" it). My apologies.
   / Purchasing Help on used John Deere 2520 #5
If you click the RED/WHITE triangle under your username you can ask a moderator to move it so as not to have double-post's.
Progressive Turf Mower- INOPERABLE / PARTS ONLY (A52128)
Progressive Turf...
Brent 420 Auger Wagon (A50514)
Brent 420 Auger...
LEEBOY 8520 APHALT PAVER (A51242)
LEEBOY 8520 APHALT...
Komatsu PC138 (A50490)
KMC 436 Peanut Inverter (A52128)
KMC 436 Peanut...
1975 Chevy C60 Grain Truck (A50514)
1975 Chevy C60...
