speedbump
There is some very good advice here and some not so good. I like the cistern at the top of the hill idea. Then you can use a 1/2hp shallow well jet to fill the cistern and you won't need a monster pump to do the sprinklers from 100' down the hill. The two horse Goulds self primer you mentioned will not even come close to what you need. It needs to be capable of 192' of head (not counting your suction lift) to give you 40 psi up the hill. It's max head is just over 100'. So at the top of the hill, you would have a trickle.
I would figure out how many gallons per minute at what pressure your heads need for each zone which should be equal. Then get at sizing a pump. It sounds like your intentions are to do this without any professional help at the site, so the more planning you do, the better it will work. If you did go with the cistern, you could use a 1/2hp 10 gpm sub in the cistern that would blow a way a 3/4hp jet pump.
