Snow Pull behind snowblower
   / Pull behind snowblower #1
carlhwv
Frederick MD - soon Seymour TN
Kubota M7040HDC
My neighbor just bought a B26. We share a 1/4 mile lane. We can have snowy winters, most storms are in the 4-6" range. He told me about a pull behind blower he is looking at. Anyone have experience with these? I just have an 84" bucket and back blade on my m7040. I mostly use my 4wheeler and blade on the smaller snows as it goes pretty quick. Not sure what model he is looking at but it has to cost some $$$$. Are we going to see some value it this attachment ?
   / Pull behind snowblower #2
Not sure about newer rear pull blowers but the older ones work good if rear tire had chains,only problem we had was pack snow drifts
   / Pull behind snowblower #3
pull behinde snowblower works just fine, is it a 2Stage or V type? If it is V type make sure it is straight side walls on it otherwise you're going to be royal p**** first time it's wet snow to blow
   / Pull behind snowblower #4
Your M7040 might be able to pull one, but not a B. You need to be able to drive throug the snow & drifts. My L3200 often had problems with drifts & wet heavy snows here in CO. Pull behind is cool if you are big enough to drive through the snow & pull it. If 6" is the most snow you get probaby not an issue, unlike the 3-4' drifts I get.
Thanks for the feedback guys. We talked about it this morning while we were laying salt for the for the freezing rain that fell. It's a two stage and he really wants it. In 10 years we have only had three big snows over 18" so I guess we will see. I guess the bucket will get a workout on any bigger ones.
   / Pull behind snowblower #6
Our former neighbor used to clear our 1/2 mile access road with this type of blower. He just made a pass every 4-6" of snow. He was retired and really enjoyed it!!
   / Pull behind snowblower #7
Friends don't let friends stop them from spending money on implements. :)
   / Pull behind snowblower #8
I use a pull behind for the bulk of my clearing, and love it. For me its the best way by far to clear my 6/10 mile road and my neighbors odd shaped drives. I even like it better than a previous front blower.
In this case I would have 2 areas of concern, hp and weight. It looks like he only has 19 pto hp and tractor is relatively small for a heavy rear implement hanging off the back. Generally speaking you usually see inverted blowers on larger tractors and as a result there are not many smaller blowers on the market, I just did some looking and found 2- 60 in ( erskine and lucknow) and 2 68in (normand and mk martin)
Of those i am guessing the erskine might be the easiest to get in the mid-atlantic but it is pretty heavy-840 lbs - that might easily cause steering issues on snow unless you put a fair amount of weight in front. The lucknow is almost 300 lbs lighter and has a bigger fan (22 vs 20 inches) but i am guessing they might be a bit hard to come by
if they go up to the 68 in blowers they then can clear a 10ft swath in one up and back but might have to go a bit slower. Can't seem to find a weight on the meteor but the normand is about the same as the lucknow.
As far as use an inverted works great on a 4-6 inch snow, where there could be an issue is if you get a noreaster and don't clear during the storm- an inverted blower needs you to be able to drive the tractor through the snow- if you can't drive through it you are bucketing or backing up and going forward repetitively. On that small a tractor i don't think the lift height would be enough to really enable the second method.
Not sure if the drive is paved- that really helps with any blower in an area with marginal temps as you may not get to build an ice layer to protect the gravel. One of the things i like about my pull blower is that i use it for pretty much any time it snows, even quite small ones, if i waited for a big snow like most do with a rear push i would not see the value as much.
hope this helps
Very good points. We have blacktop. He got turf tires and has it chained up on the rear. I'm a bit concerned about his front but I guess we will see pretty GUI like how it goes. His drive is steer...12.5 degrees for about 100 yards till it intersects the lane which is 4-7 degrees to the top. I've got enough weight coming in about 10k lbs and don't use chains in fear of destroying the blacktop. Half the snows it's quicker for me to run the 4wheeler up and down with a 60" blade. I tried going down to his house but needed chains to plow up. I tried the tractor one time and lost traction enough not to feel comfortable. I really appreciate the feedback which will help us plan our strategy. With one ice storm under our belt so far I think we will have ample opportunity to figure it all out.
   / Pull behind snowblower #10
if he does not have blower yet i would lean toward the normand, on plow site numerous posters have claimed that they plus less than the alternatives. I have a pronovost and it does really well with the wet stuff but they don't make them small enough for him
I would say with chains and on pavement he would do well , just won't be able to haul ***, he may end up wanting front chains for control but he ought to try filling his bucket for a counter weight first
2022 JOHN DEERE 85G EXCAVATOR (A51242)
2022 JOHN DEERE...
UNUSED FUTURE MINI SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE MINI...
2015 CATERPILLAR 272D2 WHEELED SKID STEER (A50458)
2015 CATERPILLAR...
30ft Sticks Mix Match Irrigation Pipe with Trailer (A52128)
30ft Sticks Mix...
1000 gal Fuel Tank (A50514)
1000 gal Fuel Tank...
1998 CATERPILLAR TH103 TELESCOPIC FORKLIFT (A51242)
1998 CATERPILLAR...
