Rotary Cutter PTO yoke broke
   / PTO yoke broke #11
so the shear pin should be what attaches the pto to the gear shaft?
Your cutter is designed to have a "fuse" in the drivetrain, either a shear bolt OR a slip clutch. If you don't have a clutch (mounted at the implement end) before the gearbox, then the "fuse" is that bolt (usually 1/2") that tessiers mentioned. If you have a shear bolt make sure it is a grade 5 bolt and NOT a grade 8. You're not looking for an indestructable bolt in this application. You WANT it to shear (i.e. blow the "fuse"). I carry a half dozen extras on the tractor. I've seen a few yokes break but it's always because the drivetrain was put into a position that were beyond the mechanical limits, usually when the pto was running. Turning in too small a radius with a manure spreader will do it. Dead Horse has good advice to operate an implement through the full range of movement with the PTO running. Once you do that, make sure you record or mark the settings of the top link if you use it on multiple implements.
Hitting a log (or other obstacle) is pretty common so you've got to make sure that the shock to the system DOESN'T get transmitted to the tractor. If you blew a perfectly good yoke and you replace it without making sure something else gives first (clutch or bolt), you'll be doing it again.
   / PTO yoke broke
WELL I HAVE HAD THIS MOWER FOR AT LEAST TWO YEARS AND HAVE NEVER DONE THIS WITH THE MOWER. AND THAT SHEAR PIN EVERYBODY IS TALKING ABOUT IM PRETTY SURE ON MINE IS LIKE A GRADE 8 BOLT THAT WAS SAID, THE ONLY REASON I SAY THAT IS ITS NOT TIGHT AND THERE ARE 2 NUTS THREADED ON IT.
   / PTO yoke broke #13
Yep, that's the shear bolt. As already mentioned, it needs to be a grade 2 bolt - no markings on the head. I also keep at least 6 or so in my little toolbox on the tractor. Sometimes I can go a couple years without breaking one, then can break 4 or 5 in one day - just the nature of the beast. If you cut alot of saplings etc. regularly you might go to a grade 5 bolt but you run a heightened risk of the damage you already have had. A grade 8 bolt is just looking for trouble. Most the time when I break a bolt the end with the nuts on it usually land on top of the cutter close to the gearbox and I reuse the nuts for the next bolt. And yes, it should be a little loose in the hole - makes getting the broken piece out easier when it sticks in there. I have used 7/16" bolts before even in a pinch with no problems.
   / PTO yoke broke
yea skipmarcy i just bought a 506 jd mower and im pretty sure thats not shear bolt either the reason i think this is there are marking on the bolt head but i could be wrong and the drive is weird the shaft from the tractor comes back close to the gear box in 6 spline but then converts to alot of smaller ones i havent counted yet and that is driving a plate that is fit inside of the same thickness of plate with a bold through it and sides that are bent on 90 degrees around so it sits in and it is surrounded what type is that i will post photo later tomorrow or saturday
(INOPERABLE) DYNAPAC 772 DOUBLE DRUM ROLLER (A58216)
(INOPERABLE)...
2008 TOYOTA Sienna AWD Van (A56859)
2008 TOYOTA Sienna...
2016 John Deere 35G (A55272)
2016 John Deere...
Ford F-350 (A57148)
Ford F-350 (A57148)
1996 International 4700 Box Truck, VIN # 1HTSCABP2TH265415 (A57453)
1996 International...
JOHN DEERE 544G WHEEL LOADER (A58216)
JOHN DEERE 544G...
