PTO Quick Attach?
   / PTO Quick Attach? #1
JohnMaldaner
Hickory, Kentucky
Kubota L2501
Is there such a thing as a quick attach accessory for the PTO? I've got a quick attach for the 3-point hitch, but still, attaching the shaft of the bush hog to the PTO is a PIA. I've got a Kubota L2501 and the shield over the PTO, plus the longer reach to get to it because of the quick-attack hitch for the 3-point, makes this final link up a frustrating chore. Anything out there to take the pain out of this?
   / PTO Quick Attach?
I am sure that I will be chastised by the safety police, but. I took the PTO guard off of my L3301. It made PTO hookup very difficult, and would often interfere with the hydraulic hoses for my BH77 backhoe.
Jack
Tell you what, at this point I might just remove mine, hook up, and put it back on. You are right. It’s disgustingly difficult with the guard the way it’s located.
   / PTO Quick Attach? #5
Hold the pto shaft an inch or two higher than it needs to be with a bungee cord.
Pushing it down a little is much easier to line it up with the splines than trying to hold it up
   / PTO Quick Attach? #7
Not that I've ever heard of. The bungee cord trick is about the best it gets. John - you must suffer along with the rest of us.
Quick attach PTO or a permanent rodent repellent. Create either - you are a rich man.
   / PTO Quick Attach?
I fear you are right! One thing I just learned about (yeah, I’m a bit slow on the uptake) is a PTO extender. That would seem to me to help a great deal. I could at least then see what I’m struggling with. I hear TSC sells them. Worth a try.
   / PTO Quick Attach? #9
On my Kubota tractors, that PTO shield pivots upward for better access. Sometimes the bolts are too tight making it appear to be fixed in place.
One trick I've learned is to connect the PTO shaft BEFORE attaching the implement to the 3pt hitch. That way, you have more room to work.
Keep the spline clean & well lubed and put the cover on when not in use. A shot of WD40 in the shaft coupler also softens the dried grease and helps the teeth mesh.
   / PTO Quick Attach? #10
I have tried to connect an implement to the tractor PTO for the first time.
I could not get the attachment to slide onto the PTO. I think it is a subtle alignment issue between the female splines of the implement and the male splines of the tractor PTO.
New PTO powered implements, connecting to new tractor PTO splines are always difficult. Once implement and tractor PTO parts are somewhat worn in, mating becomes easier.
Clean mating parts, lubrication and technique are the keys.
Most here like Eureka Fluid Film as PTO lube. I prefer wax chain lube in an aerosol can.
Grease is too thick.
WD-40 burns off. Shaft goes on "OK" but can be difficult to disconnect when hot.
Connect the implement to the tractor via two Lower Link pins and one Top Link pin. Lift implement hydraulically until implement PTO shaft and tractor PTO spines are perfectly level, one with the other.
Turn tractor engine off, disengage PTO so tractor PTO splines can be turned by hand.
Turn male splines by hand until they align with female shaft indents. Slide shaft onto tractor splines. Retract whatever type of detent you have, button or collar, then push the implement shaft the final two inches onto the tractor PTO stub.
If the PTO shaft and tractor splines are NOT perfectly level it is almost impossible to slide implement shaft on to PTO splines.
I am 74 years old. I can mount implement and connect the PTO on my heavier tractor without too much difficulty in five minutes
Hi folks...took a bit of time and fussing but wanted to update you. PTO connection problem was resolved by leveling the implement to the PTO.
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
RoGator RG1100C (A51039)
RoGator RG1100C...
2022 Club Car...
PENDING SELLER CONFIRMATIONS (A51219)
PENDING SELLER...
2016 Ford Taurus AWD Sedan (A48082)
2016 Ford Taurus...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
