PTO problems
   / PTO problems #1
Muley Gil
'49 Ford 8N
Let's try again. My friend's newish JD 1025 is having a PTO problem. There are three positions available. All the way forward is 540, middle is 2100 & 540 and the rearmost position is 2100. When in the rearmost position, the PTO shaft is not spinning.
Thoughts/comments?
   / PTO problems
Back to the top with better info.
   / PTO problems #4
Does the mid PTO spin in the middle when both shafts should be turning?
   / PTO problems
I'll have to check with my buddy. Presently, he has the PTO cover off, trying to figure out the problem.
   / PTO problems #6
If checking, verify the PTO,s are working correctly in the other two lever positions. I.e. rear 540 only and both 540 & 2100 in mid position.
That should provide some information on if the shift linkage is operational for PTO selection
   / PTO problems
That should provide some information on if the shift linkage is operational for PTO selection. The PTO works in those two positions.
   / PTO problems #8
Is this newish enough to still be under warranty? If yes I would get the dealer involved before tearing anything apart.
If not under warranty I would look very closely at the shift lever and all the linkage to see if something is preventing it from moving fully and engaging the mid PTO only. I.e. a stick, mud, grass, etc. possibly preventing full movement.
   / PTO problems
Well, my buddy took the PTO apart & everything looked good inside. No chipped gears, nothing broken or out of place. He put it back together & the PTO works in the forward position, the mid position but not in the rear most position.
   / PTO problems #10
Did your buddy confirm the shifting fork movement to engage the different gears in all three positions? Sounds like a shift collar is not being moved properly to engage mid PTO only.
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
2025 8ft Office Shipping Container (A49346)
2025 8ft Office...
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
CATALOG IS A GUIDE ONLY!! (A50774)
CATALOG IS A GUIDE...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
Misc Printer Toners and Ink Cartridges (A48083)
Misc Printer...
