PTO not working for post hole attachment on Yanmar 1500 tractor
   / PTO not working for post hole attachment on Yanmar 1500 tractor #1
chauke
Yanmar 1500
So I finally got a chance to use my new post hole digger with my old Yanmar 1500 tractor. I checked that the PTO turned and turned the gearbox and auger after I installed it so I thought I was good to go. However, when I started the first post hole, as soon as it barely made contact with the ground, the auger bit stopped turning. The tractor throttle was all the way high. I tried this in PTO speed 1 and 2, with same results. I would have tried the 3rd speed but I have never been able to get it in speed 3.
Any ideas as to why it does this? Is the PTO shot? I changed out the transmission/hydraulic fluid (with new filter) so the hydraulics should be good!
   / PTO not working for post hole attachment on Yanmar 1500 tractor #2
Most post hole augers have a shear bolt at the top of the shaft to protect u-joints. Is it possible yours sheared off?
   / PTO not working for post hole attachment on Yanmar 1500 tractor #3
Also,
Usually PTO posthole diggers operate at near idle speed, not full throttle. Use the slowest speed possible. If the PTO shaft is turning and the auger not, it is a shear bolt. Make sure you replace it with the correct bolt. If not, it may be tractor issues.
   / PTO not working for post hole attachment on Yanmar 1500 tractor #4
Does the PTO between the tractor and post hole digger stop turning or just the auger bit? If just the bit I would suspect shear bolt like Rusty states.
Does the 1500 have live PTO or does PTO stop when you step on the clutch? If stops when you step on the clutch possible the clutch requires adjustment.
Also,
I will try it at lowest speed and look at the PTO shaft to see if it is turning (don't think it was). It was the first time I used it so it had a brand new shear bolt and actually didn't even dig into the ground at all so I think the shear bolt is ok.
I think it has a live PTO. When I first tried it, the PTO shaft wasn't turning when I had the tractor in gear. When I put it in neutral, it started turning. The PTO shaft still turned when I let the clutch out, when still in neutral. Is this expected?
   / PTO not working for post hole attachment on Yanmar 1500 tractor #7
The YM1500 is a geared tractor, so the PTO is not live. Only the YMxx10 and YMxx20 machines have PowerShift to allow the PTO to be live.
The YM1500 is on the sub-compact frame, s a 3PT PHD has to be a sub-compact to work properly. Full size PHD can often flip small sub-compacts with rocks or other items below the surface soil is hit.
   / PTO not working for post hole attachment on Yanmar 1500 tractor #8
With clutch out in neutral the PTO should spin. Was the PTO spinning when the auger bit was not?
Wow, I was not aware that I had to get attachments for a "sub compact" tractor! I am very tempted to sell tractor anyway. This one doesn't have a front loader and now may have a bad PTO, not to mention all the attachments that I have bought are not for a sub compact tractor. I might try to get a regular tractor if I can find one at a decent price and this time get one that is 4 wheel drive and has a front loader!
   / PTO not working for post hole attachment on Yanmar 1500 tractor #10
Whatever you get... NEVER OPERATE ANY PHD AT ANY SPEED FASTER THAN AN IDLE.
2019 Toro Proline 32in Fixed Deck Mower (A48082)
2019 Toro Proline...
Iron Cabinet (A50860)
TOYOTA 7FGCU25 LP SIT DOWN FORKLIFT (A50854)
TOYOTA 7FGCU25 LP...
2022 John Deere S780 Combine (A50657)
2022 John Deere...
2012 FREIGHTLINER CASCADIA (A50854)
2012 FREIGHTLINER...
2016 Ford Explorer SUV (A50860)
2016 Ford Explorer...
