PTO Cover Tip?
   / PTO Cover Tip? #1
johndeere_2210
Not sure if anyone else does this, but the rear 540-PTO shield (the small plastic unit) when removed will go on and fasten as intended on the mid PTO. Therefore, if you want a little protection from trash below while doing non-mower deck work, the PTO shield will help.
FYI- I purchased as second one and run them both (540 and mid PTO), during loader and snow work and believe the price is around $5-$6.
   / PTO Cover Tip? #2
My 4010 came with a metal PTO shield over the mid PTO. I lost it once, found it and put it back on. I don't know whether it'll also work on the rear PTO, as I use the rear one but not the mid one.
Initially, I thought the thing was maybe my hydraulic filter. Turns out, the filter is behind a cap behind the lower 3 ph shaft on the 4010. Requires removal of one of the rear wheels to get to it. No problem.
Ralph
2014 Ford F-250 Ext. Cab Pickup Truck (A54814)
2014 Ford F-250...
2015 Chevrolet Silverado Pickup Truck (A55314)
2015 Chevrolet...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A55314)
2023 Kubota U48-5...
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A55314)
2023 Kubota...
2017 JOHN DEERE Z950M LOT NUMBER 83 (A53084)
2017 JOHN DEERE...
2012 CATERPILLAR 308E CR EXCAVATOR (A52707)
2012 CATERPILLAR...
