Problem with 4330
   / Problem with 4330 #1
k4330
Bronze Member
poconos pa
Kubota 5030 hst
I have a L4330 and it keeps cutting out. I will be running the tractor then motor will quit then I hear a solenoid click and as long as the motor is still spinning it will refire on its own if the motor stops I can hear the solenoid then restart with the key... I would think it has to be a fuel shutoff solenoid.. Any ideas on how to fix it ..Thanks
   / Problem with 4330 #2
K4330 I suspect you have a bad electrical connection. The most common problem spot is the fuses slide them out and then back in, that should clean the contacts. KennyV
   / Problem with 4330 #4
I agree with what KennyV stated, IE, electrical connection.
If not a fuse, check for loose electrical wire connection from fuel solenoid back to switch. If you have a VOM meter, set it on DC volts, attach it to the fuel solenoid post, and wiggle the wire at each connection with the switch "ON". Or, just wiggle the wire with switch"ON" and you will hear the solenoid kicking on/off if a loose wire.
   / Problem with 4330 #5
The ignition switch can be the bad actor too.
jb
   / Problem with 4330 #6
Check the operator presence switch under the seat.
   / Problem with 4330
Hey thanks for the replies.. I checked all connections and the seat switch and can't make a difference.. I am going to call the dealer tomorrow and see what they have to say .. Thanks
   / Problem with 4330
I am still working on this and found the pto and clutch switches stop only the starter the seat stops both, am I wrong? .. Is there a way to bypass the seat switch to see if that helps? ..Thanks
   / Problem with 4330
Well I got it going not sure what it was but after I unplugged the fuel solenoid and used the power in the wire with the key on to click the solenoid a few times it has been running since.. I guess it was a bad connection at the solenoid .. Thanks again ..
   / Problem with 4330
Well it started doing it again so I replaced the solenoid and that wasn't it so I am taking it to the dealer...
Kubota K7874 18in. Bucket (A55973)
Kubota K7874 18in...
CONCORD CRE96018B CONVEYOR BELT (A52706)
CONCORD CRE96018B...
Case IH Maxxum 150 (A53317)
Case IH Maxxum 150...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2020 CAT 308 (A53317)
2007 Freightliner B2 School Bus (A55852)
2007 Freightliner...
