"Pre-Drill"?
   / "Pre-Drill"? #1
Gomez
Bucks County, PA
Kubota B2400
\"Pre-Drill\"?
Something to think about on a Friday/w3tcompact/icons/clever.gif.
Watch any home improvement show and sooner or later you will hear the term "pre-drill". Ever since I've heard this term, it made me wonder, how do you "pre-drill" a hole? What the user of this term usually means is to drill a pilot hole to allow for some fastener to be inserted. If you "pre-flight" an aircraft, you are giving it the once over before actually flying. Does that mean "pre-drill" means measuring, marking, center punching before the hole gets drilled?
   / "Pre-Drill"? #2
Re: \"Pre-Drill\"?
Pre-Drill means to drill a hole with a drill bit rather than try to punch through the wood with a nail or try to force a screw to make its own path. Helps keep the wood from splitting also allow you to countersink the head of the screw if you so desire. /w3tcompact/icons/smile.gif
   / "Pre-Drill"? #3
Re: \"Pre-Drill\"?
"Pre-Drill" is certainly an oxymoron. It's like a "near miss", if you nearly missed something doesn't that mean you hit it? Or how about a "hot water heater", if the water is already hot, why do you nead to heat it?
I'm sure others will think of many more.
   / "Pre-Drill"? #4
Re:
Have you ever seen an envelope address and stamp itself??? I haven't. I always have to pre-address and stamp my envelopes/w3tcompact/icons/smile.gif. C
   / "Pre-Drill"? #5
Re: \"Pre-Drill\"?
Vacillate back and forth.
Close proximity.
   / "Pre-Drill"? #6
Re: \"Pre-Drill\"?
One of my favorites that people use...."unthaw"....I believe that would mean you are going to freeze it!!!
Kevin
   / "Pre-Drill"?
Re: \"Pre-Drill\"?
I'm constantly correcting my wife about that one.
   / "Pre-Drill"? #8
Re: \"Pre-Drill\"?
I hear the term "pre-existing" a lot. What was it before it was existing?
   / "Pre-Drill"? #9
Re: \"Pre-Drill\"?
The 'pre-drill' and 'pre-existing' terms have been a pet peeve of mine. Also 'pre-planned' and 'pre-board' (as in airplane boarding).
   / "Pre-Drill"? #10
Re: \"Pre-Drill\"?
Following this logic, would an apple, in its natural state, just off the tree, before being skinned, sliced and put into a pie, be "prepared"?/w3tcompact/icons/wink.gif
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
M998 (A55852)
M998 (A55852)
2018 Ford Transit Connect XL Cargo Van (A55852)
2018 Ford Transit...
2017 Nissan Frontier Pickup Truck (A53422)
2017 Nissan...
2006 Ford F-550 4x4 Altec TA37M 37FT Bucket Truck (A55852)
2006 Ford F-550...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
