Pre Chamber inserts on 1210 or 1310 head
   / Pre Chamber inserts on 1210 or 1310 head #1
HurriCain
Ford 1210
Well, Got my replacement engine home and decided to do a leak down test on it before putting back in tractor. Went to spin motor over with strong arm and would only spin 3/4 turn in each direction. HMMMMM. Pulled head and found a pre chamber insert had fallen out of head and lodged between head and piston. Thankfully, I don't think motor was run that way as no signs of crushed chamber in top of piston or head. Now, Where can I find replacement Chamber inserts? TIA
   / Pre Chamber inserts on 1210 or 1310 head #2
Used head probably the best option
How that saying go? I respectfully disagree. Can't see why it would be necessary to waist a good casting head simply because of a pressed in heat shield in the head for the injector. I will post more once I find answers but I'm fairly sure that there is a repair option for this head.
   / Pre Chamber inserts on 1210 or 1310 head #4
Shibaura does/did not supply Chamber inserts separately. I've been through this problem before.
Lay-Mor Sweepmaster 400 Broom Sweeper (A49461)
Lay-Mor...
2014 International DuraStar 4300 26ft Box Truck (A48081)
2014 International...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A51222)
2018 KENWORTH T680...
OIL WORKS INC. AIR TONGS (A50854)
OIL WORKS INC. AIR...
1984 ASPT 30ft Pole S/A Towable Trailer (A48081)
1984 ASPT 30ft...
2016 Nissan Altima 2.5 Sedan (A48082)
2016 Nissan Altima...
