Power-Tracs are not cheaper in my opinion
   / Power-Tracs are not cheaper in my opinion #91
woodlandfarms said:
Is it safe, not completely, but safer than the way the boom mower seems to work.
Still seems a bit too risky. If you are cutting amongst trees then fragments could bounce off nearby trees at eye level and bounce at you. Why not just keep the mower deck at ground level and push the trees over? Looks like you have plenty of weight and traction to do that.
   / Power-Tracs are not cheaper in my opinion #92
woodlandfarms said:
It is a simple mod and undoable in under a minute.. RegL has a much better and quicker system than me, and I swear PT designed there brush mowers to do this as the holes seem to line up magically. Here is a link to RegL mod in the unhooked mode
http://www.tractorbynet.com/forums/attachments/power-trac/81330d1184543081-couple-more-video-clips-rod-locking-brush-hog.jpg
Because I am way more abusive on my equipment, I just used two bolts to hold it in place. The rod proved a little bendy by my standards of abuse.
OK, now I see. You are removing the rear stop bolts, and bolting the mower so that it can not swing. That pinned rod in the photo is an adaptation to speed the process up.
Yes, I agree it is safer than using the boom mower. The boom mower is for places you can't safely reach with any other mower.
   / Power-Tracs are not cheaper in my opinion #93
I will not argue the inherent danger with you, but what we have to mow through is not possible by keeping the mower on deck. Blackberries are an odd beast and will tangle your tractor up and make it impassable. Think of a hundred strings, each one easy to break, but you get it onto a roll and it is tougher than a 10" tree... But now I am working different for the most part. I either grapple into the grove of bushes, or I use the back hoe and drag it out. Seems to work so far...
Carl
   / Power-Tracs are not cheaper in my opinion #94
Carl
I understand. I use my grapple to push them back then turn around and back in with my flail mower. I'd just never seen the top down approach used like in your video. It didn't look like blackberrys from the distance in your video so I thought you were using that technique for saplings too. It seemed you could just push those over from lower down.
   / Power-Tracs are not cheaper in my opinion #95
Its a jungle. Blackberries, Alders, Firs, dead bodies, large holes in the ground. I love it...
Carl
   / Power-Tracs are not cheaper in my opinion #96
Carl
Where in SW Washington?
   / Power-Tracs are not cheaper in my opinion #97
Woodland, just outside of Vancouver, just outside of Portland.... 2 miles off the 5 freeway...
   / Power-Tracs are not cheaper in my opinion #98
OK, hence the screen name. :)
I used to live over in Clark County right on the East Fork of the Lewis. Vertical waterfront. :p
   / Power-Tracs are not cheaper in my opinion #99
Carl
Carl, Have you considered spraying that mess with something like Roundup, and go back several weeks later and cutting things down. You should be able to cut that stuff with no problem with that machine of yours. There are several reasons for using chemical products. Roundup kills right down to the roots. So this is not usually a repeat operation. You can replant something/anything in about three weeks.
   / Power-Tracs are not cheaper in my opinion #100
Carl, Here is a useful tool that would help get rid of those small trees, say up to 2 or 3 inches.
UNUSED FUTURE 80R RIDE ON POWER TROWELL (A57193)
UNUSED FUTURE 80R...
TROYBILT TB685 EC WEEDEATER (A54757)
TROYBILT TB685 EC...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
2016 Ford F-150 4x4 Pickup Truck (A55852)
2016 Ford F-150...
2018 Kubota L2501 (A53317)
2018 Kubota L2501...
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
