Power Steering just quit on TC40D
   / Power Steering just quit on TC40D #1
Qapla
Veteran Member
Gator Country
New Holland TC40D HST 4WD FEL/BH
The power steering was working just fine. We were using the tractor and the power steering had two problems. It seemed to quit steering then it blew what I think is the return line from the steering piston. It is the line that has a hose clamp on it.
We re-secured the line and tightened the clamp. We also had to add hydraulic fluid to the tractor (we also blew a loader line earlier that we had to replace - so we lost a bit of fluid).
The tractor still will not turn. The steering wheel will spin freely in either direction. If we lift the front end off the ground it will attempt to turn the wheels. We can also turn the wheels by hand by grabbing the tire while the front end is raised - but while turning the wheels this way the steering wheel does not turn just because we are turning the wheels.
We were able to get the tractor from the field to where we work on it by "kicking" the front tire in the direction we wanted it to turn while the tractor was moving slowly.
Any ideas or help would be greatly appreciated.
   / Power Steering just quit on TC40D #2
I am seeing a separate power steering tank under the hood for the TC 40D from the parts diagram. Did you check the fluid level in it? It is a combination tank and filter with a rubber stopper/dipstick in the top. If it is low, add NH tranny fluid, then try to bleed the line to the pump by loosening a line while the tractor is NOT running. Once you get the fluid to the pump, retighten, then start at idle and with the steering lifted of the ground, work the steering wheel lock to lock. It may take a while. Good luck.
Thnx. We found the power steering tank after I posted. We have to get some fluid to proceed.
Will post the results - should be tomorrow.
Fluid filled, system bled, steering back working just fine.
Thnx
2015 DODGE RAM...
2022 Adams CLC-1013 Conveyor - New (A51039)
2022 Adams...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A51222)
2020 INTERNATIONAL...
2012 John Deere 9560RT Track Tractor (A50657)
2012 John Deere...
1997 Mercedes Convertible (A48082)
1997 Mercedes...
2015 Freightliner Ambulance (A50323)
2015 Freightliner...
