Power steering fluid coming out reservoir, help!
   / Power steering fluid coming out reservoir, help! #1
johnking
greenville sc
1965 Massey 135
I just bought a ford 3000 with add on anadolu PS unit. It ran fine for 10 hours and then PS fluid started coming out of a hole in the cap(which I believe is a spray paint can top). I removed the reservoir today and found that the filter has catastrophically failed(top separated form the bottom). I am not a PS guy so I am using my limited knowledge base. This small cylinder shaped filter has a solid metal top and screen forming the circumference. I am assuming that this acts as a baffle the slow agitated PS(ATF) fluid and thus this is why fluid is coming out of the little overflow hole. Am I on the right track? If I am. I need to find a substitute for this filter due to the age and make of the PS unit I think it will be next to impossible. If anyone has a substitute part # or source please let me know. The filter screws onto the incoming oil fitting. I am thinking I can get some screen and putting it in the reservoir or get a elbow plumbing fitting but I am really at a loss, please help.!
Anadolu parts are ungoogleable. I have emailed the company. I think I might be able to rig a close substitute out of a foot valve from the plumbing section at lowes.
2015 Jeep Cherokee Latitude SUV (A55758)
2015 Jeep Cherokee...
Toro Multi Pro 5800 (A55758)
Toro Multi Pro...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A55314)
2023 Kubota...
Year: 2011 Make: Jeep Model: Grand Cherokee Vehicle Type: Multipurpose Vehicle (MPV) Mileage: (A55853)
Year: 2011 Make...
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51691)
2015 Toro Multi...
