Power Steering Cylinder
   / Power Steering Cylinder #1
tractorpilot
Central Wisconsin
New Holland TC33
Reading the archieves, it would seem I am not the first to bend the rod on my power steering cylinder. I am trying to take it off to bring it to a rebuild shop as NH wants $487 for a new one.
Problem is this - the cylinder is hanging by the hydraulic lines and I cannot loosen them from the cylinder with a normal size wrench. Before I get out the cheater, I wanted to ask if anyone knows if this might be a reverse thread?
   / Power Steering Cylinder #2
I am sure you have normal right-hand-thread hyd connections.
Most modern CUTs use a 37-degree JIC compression fittings, but
I have no personal experience with NH (Shibaura) machines.
Water gets into the threads and causes corrosion....they do not
need to be torqued down tremendously tight.
A slightly bent rod can be repaired, or a hyd shop can make a new
rod for you for maybe $100.
   / Power Steering Cylinder #4
I think it's safe to say that left-hand threads are used only on things that
  • normally rotate in a counter-clockwise direction (e.g. lug nuts on the left side of some cars)
  • some gas fittings (to prevent incorrect connections)
  • one end of a turnbuckle
So as dfkrug stated, your hydraulic fittings are normal right-hand thread.
I once spent a lot of effort trying to loosen a bolt on the back end of the engine in a '57 Chevy. I gave up, ate lunch, and then realized that the bolt was threaded toward me. Duh. I was much younger then and had energy to spend.
tractorpilot apparently has already had that experience and that's why he/she's posting this question.
   / Power Steering Cylinder #5
TedLaRue said:
I once spent a lot of effort trying to loosen a bolt on the back end of the engine in a '57 Chevy. I gave up, ate lunch, and then realized that the bolt was threaded toward me. Duh. I was much younger then and had energy to spend..
Good list, Ted.
I ran into a left hand thread on a shaft inside a transmission once, but
it WAS Italian. Ruined it trying to get it off.
My JDs used compression fittings. Can't recall if they were metric
or -4 JIC on the FEL. My older Kubotas used a metric comp fitting.
My Kioti uses the only -5 size JICs I have ever run into.
Thank you for the feedback - I bounced this question off of our maint supv where I work - he used to work for a JD dealer. After giving me a load of crap about buying blue, he told me to forget about the joint at the cylinder and go after the swivel joint up above. Two wrenches and a cut knuckle later, I had the cylinder on the bench where I could get some leverage on the fitting - new hoses will be the result. Now if they can straighten the rod. Thanks again.
   / Power Steering Cylinder #7
After you straighten the rod, weld a piece of angle iron to it to strenghten it. I bent my 1710 and 2120 tierods a few times but one I did that I've run for years without so much as a hickop. Don't worry about adjusting the length anymore. Once it is set you can just fix it to that length.
Andy
   / Power Steering Cylinder #8
Andy
He is referring to his power steering hydraulic cylinder rod. Not all tractors
use a cylinder(s) to operate the power steering.
   / Power Steering Cylinder #9
Hey pilot, I don't know what size tractor you have but on my 4600 I had the rod straightened count em, 3 times. I found I could buy a new cylinder from Mid South Tractor Parts in Decator Alabama for $100.00 plus shipping. The phone number is (256)353-5661. Lee Taylor is the owner I think. He is the one who helped me.
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
2015 Ford E-350 Passenger Bus (A50323)
2015 Ford E-350...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
UNUSED FUTURE MINI SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE MINI...
2006 KENWORTH T300 SERVICE TRUCK (A51243)
2006 KENWORTH T300...
2003 MERCEDES-BENZ SLK-Class (A50324)
2003 MERCEDES-BENZ...
