CTyler
Veteran Member
Pole barn heating Q\'s
I have a 50x64x12 insulated pole barn. I'm finishing off a 16x50 side of it and have it framed up 75% wired and pumbed.
Within the finished area we will be using a ventless 30k btu blue flame propane heater.
Q1) Do I need to keep the propane line x amount of feet from electrical? My electician I contracted to wire my house wasn't sure. Haven't asked my plumbing/HVAC contractor.
The rest of the shop will be heated with wood via a double barrel wood stove kit. The flu will be 6".
Q2) What is the best way to cut a hole in the steel roof?
When I installed my vent pipe for plumbing I had a hard time with the sawzall. The metal wanted to flap all over making it real hard to get a nice cut.
Q3)Would a jigsaw do the same thing as the sawzall? I.E. flap flap flap. /forums/images/graemlins/frown.gif
I need to check local codes in wether we need double or triple wall through the roof.
Q4) Regarding the damper in the flu. What is the proper setting? Do you try to match the intake?
I've never used a damper in a wood stove. We always adjusted the air intake for desired heat. Then at night turn it most of the way down so you still had embers in the morning.
Q5)I have read that the ventless heaters are picky about fumes from WD-40 paint etc.. Am I going to get funny smells or anything running the heater and the wood stove? We were thinking about adding one to the shop side as well.
I know this is a bunch of questions....Thanks!!
