Polan 2150PR
   / Polan 2150PR #11
Doesn't spark or sometimes? If you get some spark disconnect the wires at the switch and try. but I am going to "guess" coil.
   / Polan 2150PR #12
I know this is not high quality saw, but it only has 4 hours on it and it was given to me. After I replaced the fuel lines and cleaned the carb, I put it together and it starts on the first or second pull but will only run until it gets hot, then quits. After it cools down it will do the same thing. I have about 40 dollars in it right now for parts(fuel line, carb, and orings for caps). I was thinking that the only thing that would be left would be the coil, but a new one runs 30 dollars and it that doesn't fix I will have 70 in a non running saw. So my question is, would it be the coil? Should I even continue trying to fix it? What else could it be?
Simplest fix is to look at the muffler screen. Being relatively new I would not think of a carbon build up unless whoever had it ran it heavy with oil but their might be a debris build up that cannot be blown out or burnt up. This is just how a saw will act with a plugged screen as well. If not this, replace the coil.
   / Polan 2150PR #14
I am with the check the switch crowd first but I believe a coil is a high probability also like the rest.
fwtw My brand new craftsman 4 stroke mini tiller would start running like crap once it warmed up and thats what the warranty repair shop replaced (coil) and it runs like a banshee now.
   / Polan 2150PR #15
First thing is get it hot until it quits again then squeeze the metal crimp from the plug wire cap to make sure it is making electrical contact and try it again. If it still doesn't run then replace the plug and try again. Plugs do go bad at times. If the doesn't work after all of the other things you have done then you may have a bad coil
   / Polan 2150PR #17
If it dont spark when hot, thats the problem. Either a coil, or wires going to the coil from the switch.
2015 Chevrolet Silverado 2500 HD Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
2000 INTERNATIONAL 4900 DUMP BODY (A56138)
2000 INTERNATIONAL...
2015 Ford F-350 4x4 Pickup Truck (A54814)
2015 Ford F-350...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A55314)
2008 Ford F-250...
CASE CX330 EXCAVATOR (A52707)
CASE CX330...
