Plate Compactors for Tractor?
   / Plate Compactors for Tractor? #1
MoLife
Kubota L6060
Hi all,
Looking for a plate compactor for my L6060. Came across a couple of companies that make these:
However their minimum use GPM is 12, while the pump output of the L6060 is 9.4gpm.
Anyone know of another brand or type of compactor that would work?
Thanks all!
   / Plate Compactors for Tractor? #2
I've not heard of plate compactors for tractors. Before you go much further - check with your Kubota dealer. I'm not sure that utility tractors are designed to run compactors. These are usually considered to be an industrial implement.
Compactors are not listed as implements suitable to use on my M6040.
I would suggest renting a walk behind compactor.
Bolens G272 Tractor (A50860)
Bolens G272...
2013 Dodge Charger Sedan (A48082)
2013 Dodge Charger...
2013 Volkswagen Passat Sedan (A48082)
2013 Volkswagen...
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
2021 New Holland P2350 Air Cart  New, Tow-Between, Intellirate Control, Dual Tires (A51039)
2021 New Holland...
2008 Saturn VUE XE SUV (A50860)
2008 Saturn VUE XE...
