Planting yellow clover seed
   / Planting yellow clover seed #1
RobA
Platinum Member
Chester County, SE PA
Kubota L5030 HST
I will be planting yellow sweet clover for my bees. I bought seed (too much) and inoculant. Was reading that yellow clover seed may need to be scarified before planting. Anyone have experience with this? If it is necessary is there an easy way to do it?
   / Planting yellow clover seed #2
I saw this post a few days ago, (I did try planting some clovers and had very little success) it was very dry, (had a time finding it again).
but I think when they talk of scarifed seed, my guess is it could be done by hand on a few seeds, I think they either use chemical of some type of machine, to do it,
but a number of years ago, I was talking to the director of the FSA and when he was in collage or just after one of the jobs he had was with a large state park, and of the jobs they had was fill in areas where the grass was damaged, and under normal situations it could take up to three seasons, for the grass to come up, so they would lightly moisten the seed, then freeze it (in chest freezer), and then after it was froze good, take it out and let it thaw, and then when thawed, refreeze it and thaw it for at least three cycles, and then plant it. and most of the time it would come up that season,
(just a thought, been thinking about making and trying this machine for dehulling or for threshing small batches of grasses and small grains, but have not tried it,
but the thought was to take two wide tires and put on axels, (use air pressure to control the pressure between the tires) but hook the shafts together with roller chain but drive the axels with sprockets that would be off by one or two teeth, so they are not rotating at exactly the same speed, thus with a small speed differential, either rolling the seed, to dehull it or thresh it out of hulls, (now I do not know if some thing like this would "polish", " scarifed" or not,
some of the other Ideas I read about is using hot water, (not boiling) for a few seconds, and chemical acid treatments, If one had time to test methods, one could try to see what would work with destroying the seed,
but the freeze thaw method is most likely the safest, but one may still want to test on a small batch before committing the entire amount to the process,
Good luck on the planting,
   / Planting yellow clover seed #3
i have yellow sweet clover growing for the same reason. as a forage for pollinators. its a biennial and this will be the second year of bloom and 4th year since seeding. i just kind of threw the seed out there and waited. it has to be in a field you don't mow during the growing season. i probably ran the disk over the field before planting and then lightly again to cover the seed. i used innoculant and did not scarify.
Thanks. It's in an area that gets mowed once a year, maybe. I'll drag the area, seed by hand and re-drag it again. I think I'll skip the scarification and just use the inoculant.
   / Planting yellow clover seed #5
Years ago I planted Yellow Blossom Sweet Clover along and under an Osage Orange hedge row. About 400 feet by 30 feet. IIRC I just threw it out and raked it in (might have used an inoculant). It grew beautifully about 3 feet tall for a couple seasons IIRC. Our orchard of 20 varied fruit trees were right next to it.....but that was 40 years ago. Also had an acre of red clover in one field at that time. Those were the days.
Best of luck to you.
   / Planting yellow clover seed #6
I used all red (alsike) clover in a sandy situation, did wonders for my next years grass cuz it is legume of sorts. create a nitrogen source in the soil, Lots of water necessary 1st year. Bees love it, makes nice tasting honey too.
Hope it's no too late to sow some seed.
Misc. Electronics (A50860)
Misc. Electronics...
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
2018 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A51222)
2018 INTERNATIONAL...
2016 FREIGHTLINER M2 DAY CAB (A51222)
2016 FREIGHTLINER...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
